Re-Routing the coolant Hose, help please
Old Mar 26, 2006 | 03:03 PM
Crusin' 1980's's Avatar
Car: 1988 SC Camaro
Engine: 305 TBI
Transmission: 700-R4
I'm sure someone has done this before, and i hope you could help give me suggestions on how to re-route the hose that runs over the passenger side valve cover...the Transmission Dipstick seems to prevent me from just running a longer hose....is there some kind of 90 degree elbow that i can use to divert the diptick and route the hose along the inner wall of the fender?...and suggestions and/or pictures would be helpful, Thanks!
[IMG][/IMG]
[IMG][/IMG]
Old Mar 26, 2006 | 10:01 PM
Car: 1988 SC Camaro
Engine: 305 TBI
any suggestions?...wasn't there a thread that dealt with something like this?
Old Mar 26, 2006 | 10:57 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Yes, there is a dealer part which was on your car stock. It bends down to a metal line, goes along firewall then up the frame rail where another hose takes it to the radiator.
Old Mar 27, 2006 | 10:29 AM
DNSTA's Avatar
Car: 1991 Camaro RS
Engine: 355
Axle/Gears: 4.10
He is right. The car came stock with a metal tube that routed the hose down along the frame rail. I am actually in the process of doing the exact same thing in my car. I need to search the junk yards to get the tube. I bet I don't want to pay for it from the dealership.
Old Mar 27, 2006 | 12:44 PM
Car: 1988 SC Camaro
Engine: 305 TBI
Can anyone take a picture of what the proper routing of that hose looks like, and what that metal piece looks like? Thanks
Old Mar 27, 2006 | 12:51 PM
Slow89Iroc-Z's Avatar
Car: 1989 Iroc-Z
Engine: 350ci SBC
I did it last summer...here is a post with some pics....
https://www.thirdgen.org/forums/nw-indiana-south-chicago/314161-clean-up-passenger-side.html
Old Mar 27, 2006 | 02:01 PM
Car: 1988 SC Camaro
Engine: 305 TBI
VALVE QUESTION
Thanks...the pictures were a bit difficult for me to discern...do you have any specific information/details on what parts you used to re-route the hose? How about the heater/coolant valve show in this picture, is there anything that looks nice that this or has anyone found a way to hide this from plain veiw...its pretty ugly...[IMG][/IMG]
Old Mar 27, 2006 | 07:14 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
I hated the stock metal line running along the frame rail - and it put the hose close to my headers. I just run the hoses on each side of the tranny dipstick - squeezed the dipstick in the middle. The dipstick will move a bit, if you push on it - it attaches to a top tranny/motor bolt - but that piece will bend slightly given some pressure.
The newer cars have a black plastic valve to replace that older metal valve that you don't like the appearance of (in your second pic) - that's the heater diverter valve - the vacuum line connects to your heater controls in the dash - when you have set to warm, the valve allows hot coolant into the heater core - when set at cold, the vacuum closes the valve to keep the hot coolant from the heater core - it can be removed and just use solid hose from point a to b, but then you'll have a small amount of warm air in the cabin during the summer when you may not want it, from the hot coolant circulating in the heater core. I removed mine - I'll have the t-tops out anyways, I'll never notice that heat when the sun is shining and it's 95 degrees with the tops out!
And TAKE THOSE GLOVES OFF!!!! None of this is any fun without greasy hands! It's the only peroof that you actually did it yourself! LOL
Old Mar 27, 2006 | 07:52 PM
Car: 1988 SC Camaro
Engine: 305 TBI
LOL, thats funny that you said that...I use to work on my car a bit without the gloves, but i had to wash my hands numerous times to get the grease off. Once i began using the gloves, i loved em...i don't think i can touch the car without them!
Old Mar 28, 2006 | 03:44 PM
Car: 1992 RS
Engine: Carbed 350
I could never get any work done with them - they always tear, or the tips hang off and get in the way, or some fluid I came in contact with ate right through - so I gave up and got myself the big jug of GoJo Orange Pumice and a nail brush. Besides - my wife would think she was with a stranger if she was touched with clean hands LOL. And even on a rare occasion, she'll get in there and get greasy with me!
Old Mar 29, 2006 | 09:05 PM
Car: 1988 SC Camaro
Engine: 305 TBI
The gloves do rip easily, but if you wear 2 pairs (like i do) then they seem to be much more durable...but anyway, does anyone have any more ideas about re-routing the coolant/heater hoses so that they're not resting on the valve cover? It seems like no matter what i try, they're still an eye sore
Old Mar 30, 2006 | 07:14 PM
Car: 1992 RS
Engine: Carbed 350
Do you still have the A/C stuff? You can get longer hoses, and route wherever - I'm going to zip-tie my back along the A/C stuff I think.
Old Mar 31, 2006 | 01:33 AM
CrazyHawaiian's Avatar
Car: too many ...
Your local auto parts store should have an assortment of hoses with 90 degree and even 180 degree bends and stuff. If the sizes aren't right you can use stepdowns. Thats how I did the throttle body coolant bypass on my IROC-Z, just went to a local Checkers Auto Parts and bought a 90 degree bended line, a stepdown, and 1 foot of hose (forget the sizes) was like $10. At the same time I deleted all the coolant lines to the firewall and stuff (this isn't a daily driver) so it looks much better. I'm sure its possible to keep all the hoses connected and run everything by the fame where its a little more out of sight. But you're going to have to spend a good ammount of time planing out how you're gonna route everything. Your imagination is the limit.
sheachopper
Jul 31, 2019 11:27 AM
ULTM8Z
Oct 2, 2015 01:25 PM
