starter
Old Mar 27, 2006 | 01:10 PM
steve87iroc's Avatar
Car: 1987 iroc z
Engine: 355 dart platinum 215cc heads
Transmission: <<BLOWN UP TH400>>
Axle/Gears: 10 bolt 4.11's
starter
ok i got a starter from a 74 corvette to use with my 168 tooth flexplate. and hooked it up but the motor wont turn it just clicks like it gets stuck. one of the bolts isnt a starter bolt could that be the problem i also tryed shimming to one shim is to much and 2 is not enough. also i can turn the motor by hand so its not locked up. thanks
Old Mar 27, 2006 | 01:25 PM
Vader's Avatar
Starter bolts (with the knurled lower portion) will make a difference for alignment. You'll need them eventually, so you might as well try that first.
Old Mar 27, 2006 | 02:07 PM
3.492rs's Avatar
Car: 89 IROCZ
Engine: L98 4150 carb
Transmission: Transgo 700-r4
Axle/Gears: 10 bolt/3.23
make sure your battery is fully charged or the starter will just click
Old Mar 27, 2006 | 06:26 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Advance Auto has starter bolts in the HELP! section.
3rd gen money
Oct 11, 2019 09:57 PM
Gunner242
Dec 25, 2015 04:49 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
Jlanz55
Sep 29, 2015 08:55 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
