heads 1008813
Old Mar 30, 2006 | 06:52 PM
dave_d's Avatar
heads 1008813
Will these heads work with my 91 z28 350 tpi
10088113
Old Mar 30, 2006 | 06:57 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
10088113...88-up...350..........Aluminum, 58cc, angle plug, raised
"D" port exhaust, 1.94"/1.5" valves
Yes it will bolt right up, only things of concern are the small chambers and D port exhaust.
Old Mar 30, 2006 | 07:34 PM
chesterfield's Avatar
Car: Pontiac
those heads have the 86 and earlier intake bolt angles(yes I know 88 and up but the aluminum corvette heads used the old intake). they also have no crossover provision for egr.
Old Mar 30, 2006 | 07:50 PM
dave_d's Avatar
I have these heads being done no w. Should I try them or just by a new set of victory jr's and go from there.
How are they as an overall head?
How would I combat the egr provision
Old Mar 30, 2006 | 08:05 PM
Car: Pontiac
I don't know about tpi stuff. The carb manifolds can be modified, maybe so with the tpi. If I was you I'd be thinking about getting a 86 tpi intake from a junkyard or the classifieds. But I'd go to the tpi forum first and ask about that. The corvette had some kind of tube going from the exhaust manifold to the egr on the intake. If you're in California or some other smog-**** location you might have a problem with that.
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
FormulasOnly
Sep 6, 2015 10:42 AM
z28guy134
Sep 1, 2015 11:50 PM
