What spark plugs to use with my Trickflows?
Old Mar 30, 2006 | 09:51 PM
TKO500's Avatar
Car: 91 B4C, 17 C7 GS, 16 Denali DMax
Engine: LS3, LS3, LML
Axle/Gears: 3.23, 3.42, 3.23
My motor is all together and now I need to pick out a set of plugs to run in these heads.
Trickflow recommends:
Autolite 3924
NGK FR5
Champion RC9YC
Is anyone running an AC-Delco plug? I would prefer to run a Delco plug over these others. I am open to all suggestions.
Does anyone have any opinions on any of these?
Old Mar 30, 2006 | 10:01 PM
EvilCartman's Avatar
Car: '82 Z28
Just run a cross reference on one of those plugs to find an AC Delco plug. Parts store should be able to do that or you can use Google.
Old Mar 31, 2006 | 12:46 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I run autolite 3923's. AC is 41-629
Old Mar 31, 2006 | 08:24 AM
Slow89Iroc-Z's Avatar
Car: 1989 Iroc-Z
Engine: 350ci SBC
I run autolite with those heads too...3924's. Wal-Mart has a 2 pack for like $1.70
Old Mar 31, 2006 | 09:36 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
I used the auto lites that they called for and went up one heat range. They worked great for me.
Old Mar 31, 2006 | 12:34 PM
Car: 1989 Iroc-Z
Engine: 350ci SBC
Tibo....Why did you go one step hotter?
Old Mar 31, 2006 | 03:13 PM
izcain's Avatar
Car: 1983 Camaro Z28
Engine: 584
Transmission: TSI Glide
Axle/Gears: Quick performance 9 inch
The autolites seemed to just foul alot easier then the champions or the NGKs I run NGK fr4 (one step colder) for my nitrous motor with trickflows on it. seems like the autolites just have to small of an electrode.
Old Mar 31, 2006 | 03:20 PM
TKO500's Avatar
I got a delco number from Trickflow this morning. They told me to run a FR3LS but my napa guy looked into them and called a couple distributors and apparently they no longer make that one.
So I ended up going with the NGK FR5. They were something like $2/plug. That NGK plug is one of the other numbers I got from Trickflow.
Old Apr 1, 2006 | 09:47 AM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
You can find the autolites in more shops than the ngk's. The gm FR3LS, FR2LS and FR1LS have been discontinued.
The autolite 3926 is the stock heat range. 3924 is one step colder, 3923 is 2 steps colder.
Old Apr 29, 2006 | 01:57 PM
OUTATIME GTA's Avatar
Car: '89 GTA
Axle/Gears: 3.27/9-bolt
Fast_25th - I have essentially the same setup just finishing up.
I'm picking up the Autolites, but I'm sure the NGK's are as good if not a bit better.
What do you expect your setup to run in the 1/4?
I've got the same heads/intake/rr's, just a milder cam.
Old Jun 23, 2006 | 11:47 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
What happened to 3925's?
Old Jun 24, 2006 | 11:30 AM
Rob Wade's Avatar
Car: 89 jaguar xjs convertable
Engine: 89 L98 5.7 TPI
Axle/Gears: 3.23 dana 44
Just a FYI ,as an application, use a 1986 corvette aluminum head plug. Thats what your autolite # crosses to. I run bosch platimum 4's in my trickflows. Very happy with them.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
Jlanz55
Sep 9, 2015 09:09 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
