head gasket question...
Old Apr 1, 2006 | 11:56 AM
CreepingDeath94's Avatar
Car: '87 Trans-Am
Engine: LB9 (305 TPI)
Axle/Gears: 3.42 or 3.73..figuring it out still
Alright, Im in a panic because I just had a horrible feeling I may have used a standard head gasket in a .030 over block. What would that do? Is that something that would be pretty noticeable during assembly that if I was paying attention at all I would have noticed? Will it cause the gasket to blow? I dont build engines so I wouldnt put it past myself, but I thought I was pretty careful about evrything and would like to think i didnt do this...but just in case id liek to know where I am now. Thanks guys.
Old Apr 1, 2006 | 04:19 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
you're fine.
what motor? generally the head gasket is much larger then the bore anyway (4.166" vs 4.030" for a 350), if it wasn't, and was undersized, (extremely rare, 4.0" gasket on a 4.030 motor..), you'd have seen it as you put it together.
Old Apr 1, 2006 | 04:38 PM
Car: '87 Trans-Am
Its a 350 block bored .030 over...
3rd gen money
Sep 8, 2015 11:40 PM
355tpipickup
Aug 27, 2015 08:13 AM
NinjaNife
Aug 23, 2015 11:49 AM
qz6lwp
Aug 20, 2015 08:10 PM
