New Pro Cylinder Heads: made 70deg cut, did I ruin them?
Old Apr 2, 2006 | 05:04 PM
Blazer79's Avatar
Car: 1986 Iroc-Z
Engine: Stock 305 TPI MAF w 148,000 mi.
I bought a set of iron Pro-Lightning Pro-Topline 180cc runner, 72cc, bare heads. I took them to a shop for cutting the three angles to the new valves, but while I was there I let them talk me into making an additional 70deg cut right above the bowl, as seen in the attached pics. They assured me this would greatly improve breathing. The original three angles cut by pro on the heads are intact. They just added the additional cut.
Now I'm thinking why was I so stupid and not check with you guys first. Check out the attached pics. Can anybody tell me if this will affect performance? Or is it really a good thing?
Thanks.
Attached Thumbnails New Pro Cylinder Heads: made 70deg cut, did I ruin them?-pro1.jpg   New Pro Cylinder Heads: made 70deg cut, did I ruin them?-pro2.jpg
Old Apr 2, 2006 | 06:00 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
that's fine, you're going from a 3 angle valve job to a 4... some people do 5.
now you can whip out your die grinder/dremel, and blend the bowl into that, for even better low lift flow!
Old Apr 2, 2006 | 06:09 PM
11 Flat's Avatar
A 75 deg would of been better.... The last set of ProTopline heads I did i used a 38 45 60 75 90... Pretty much the angles i use on most of the heads i do
Old Apr 2, 2006 | 08:25 PM
Blazer79's Avatar
Car: 1986 Iroc-Z
Whew!
Thanks for your replies. I feel more relaxed now.
Jeremys87
Jul 14, 2022 09:08 PM
Terrell351
Jun 13, 2021 01:13 PM
Reddeath210
Oct 6, 2015 08:20 AM
Dialed_In
Aug 20, 2015 01:45 PM
mustangman65_79
Aug 13, 2015 07:36 AM
