89 iroc 5.7 wont start
Old Apr 2, 2006 | 09:28 PM
rdnocera's Avatar
when i went to take my iroc out of storage, of course the battery was dead. when i tried to jump it it would not do anything. no clicking, no nothing. all the gauges worked, the stereo works, headlights worked when cables were connected. is there a factory security enginge kill?? the previous owner is deceased and his father didn't know much about the car. what is VATS??? i have read on some sights about this and it sounds like the problem i am having.
Old Apr 2, 2006 | 10:19 PM
sasser43's Avatar
Car: 89 GTA
Engine: 350 TPI L98
If its VATS, when you try to turn the engine, the brake light will come on. Atleast thats how it is on my GTA. The brake pedal might be stiff also. If thats the case, you might need to check the wires going to the lock cylinder. It's two yellow wires that plug into the lock cylinder and they run down through the steering column where they hook into two individul wire connecter things to another set of two yellow wires.
Old Apr 2, 2006 | 11:22 PM
CreepingDeath94's Avatar
Car: '87 Trans-Am
Engine: LB9 (305 TPI)
Axle/Gears: 3.42 or 3.73..figuring it out still
Is your security light coming on? Staying on or turning off after a few seconds?
Old Apr 3, 2006 | 12:57 PM
rdnocera's Avatar
goes out after a few seconds
Old Apr 3, 2006 | 03:33 PM
89Vert's Avatar
Car: '89 Iroc Vert
Engine: 355 TPI
Transmission: T-5(for now)
Axle/Gears: 3.45 9 Bolt
see if it turn over if you jump the starter with a screw driver, or a push button
Old Apr 3, 2006 | 03:36 PM
Car: '87 Trans-Am
Yes, try to manually jump it with a start button. It might be your neutral safety switch as well. If that is faulty, the car wont start as it doesnt know if it is in park or not basically.
Old Apr 3, 2006 | 05:00 PM
rdnocera's Avatar
i was i the process of checking the starter when it started to rain and hail. i'll jump it later this week
Frozer!!!
Jan 19, 2024 04:55 PM
Wade787b
Sep 29, 2015 01:15 PM
89redeyeRoc
Car Audio
Aug 24, 2015 07:01 AM
jharrison5
Aug 19, 2015 05:53 PM
mustangman65_79
Aug 11, 2015 03:17 PM
