Power Steering Pump Bracket...
Old Apr 2, 2006 | 11:09 PM
12SecondTA's Avatar
Car: 85' TA
Engine: 355 Carbed
Transmission: Built 700r4
My car originally had a/c, and with my current engine build i wann get rid of that ugly as sin power steering pump bracket. But the only ones i can find are priced more expensive then my left leg is worth on the black market.
My only hope so far was this jegs power steering pump bracket, but its for short style water pumps only. Can it still be used?
Category - JEG'S Power Steering Pump Brackets
what would have to be done to use this? Or is there any other way. currently my power steering bracket is the two pieces, the one held on the a/c compressor, photo below.
What can i do?
Old Apr 3, 2006 | 11:13 AM
12SecondTA's Avatar
Car: 85' TA
Engine: 355 Carbed
bump........
Old Apr 3, 2006 | 11:32 AM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
I believe I have my old non A/C stock Pwer steering pump brackets if you want. They are even chromed. I'll double check tonite that I still have them.
The problem with the Jegs and Summit generic ones are they tend to push the pump out pretty far to the side by design. Even using a shorter turnbuckle I had a hard time keeping belt tension.
Old Apr 3, 2006 | 11:55 AM
12SecondTA's Avatar
Car: 85' TA
Engine: 355 Carbed
awesome, that'd be awesome if you could check to see if you have yours still. Not many f-body enthusiasts around here to see if they have any.
I really just want a bracket that looks better, the one i have now looks just, horrible, as you can see the only thing shiney about it is that bolt.
Old Apr 3, 2006 | 06:15 PM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
Sorry man, guess I did get rid of them. All I have are shiney alt brackets.
Old Apr 3, 2006 | 06:21 PM
12SecondTA's Avatar
Car: 85' TA
Engine: 355 Carbed
darn, anyone got a photo of a saginaw power steering bracket from a car without A/C, i need to ateast know what i am looking for!
Old Apr 4, 2006 | 12:59 PM
12SecondTA's Avatar
Car: 85' TA
Engine: 355 Carbed
bump
Glowsock
Jul 24, 2025 03:15 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
backtothe80s
Sep 5, 2015 12:39 AM
86White_T/A305
Aug 17, 2015 12:16 AM
