What kind of numbers would i be looking at?
Old Apr 4, 2006 | 12:04 AM
biguglymaro's Avatar
Well im just wondering what you guys figure these combos would put ot for power...
Eng1=
350ci
-12cc dish pistons (10.5:1??)
416 heads
Comp cams 265DEH (link to spec)
RPM air gap intake
770cfm holley
GM HEI ingnition
Eng2=
350ci
.2" dome pistons (10.3:1??)
882 heads
Comp cams XE256H (link to spec)
Edelbrock RPM pro flo EFI system
GM HEI ignition
So am i anywhere close to being on the right track here?
Im not looking for a $10,000 machine here, just something that will be a bit stronger than that old tired 305 and still get decent fuel economy. I was leaning towards the EFI because of the range of tunability which hopefully could get me a healthy motor without chugging the gas faster than i can pump it in!!!
Thanks in advance guys!
Old Apr 4, 2006 | 12:41 AM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Your running to much compression. With those cams and heads you will want 9.5:1.
Old Apr 4, 2006 | 12:48 AM
Ok thanks!
I was looking to use a set of heads i had kicking arund which are obviously a set of 416s (on motor in car) and a set of 882s (on an old 350, rod through block).
So what if i went with a bit bigger dish on eng1 and flattops on eng2, that should get me down into the mid 9:1s. Or would i be alot better off going with a 'bigger' cam?
Old Apr 4, 2006 | 10:05 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Cool, im looking at doing very similar setups but with quite a bit more cam. Report back if you get the EFI, i have always wanted to try an edelbrock or holley EFI setup but didnt want to blow the money on something thats going to take 5 years to tune!
Old Apr 4, 2006 | 12:09 PM
I will be sure to post back about the EFI setup if i get it, but im still not yet sure if its worth the gobs of money they want for it.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
1992Z28!
Nov 19, 2015 07:33 AM
lethaldomestics
Sep 21, 2015 01:18 PM
ccop
Convertibles
Sep 14, 2015 04:13 PM
Springster
Sep 13, 2015 01:38 PM
