Can an evap canister go bad??
Old Apr 7, 2006 | 10:11 PM
scanman717's Avatar
Car: 92 Z/28 Convertible
Engine: LB9
Transmission: Mad Dog Auto 700R4
I got some serious gas smell under the hood front near where the cannister is. It only happens when I run the car for a while and get the temp up and run for a while.. IE when I come home from work, and park in the garage, the whole garage smells like gas very quickly. But if I just drive around the block or a similar short trip, I don't have the odor.
I was thinking maybe leaky fuel injector, so I replaced them (130k miles, time anyway) Didn't fix the bad smell.. So I have traced every line from the gas tank into the engine bay and could not find a leak.. At this point I am stumped, I replaced the vacuum line from the throttle body to the canister, but that didn't help.. So I am wondering if they simply go bad after a while..
Old Apr 8, 2006 | 08:14 PM
CEP89's Avatar
Car: 89' IROCZ
Engine: 5.7 L98
Yes they can get saturated with fuel if you overfill you gas tank. They can also crack and the valve on can go bad.
Old Apr 10, 2006 | 12:03 AM
87TAairlineyard's Avatar
Car: 1987 Pontiac Trans Am
Engine: 305 LB9 Tuned Port Injection
Transmission: 700-R4 Automatic
Axle/Gears: Saginaw 10 bolt 2.73 posi
Did you remove the canister and replace the filter? It might be saturated or worn out. Worth a shot, the filters are very inexpensive.
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
3rdgenkindagal
Aftermarket Vendor Review
25
Oct 21, 2015 09:32 AM
Racerx974
Sep 19, 2015 10:16 AM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
gta892000
Sep 16, 2015 12:40 AM
