cam install...
Old Apr 8, 2006 | 01:59 PM
CreepingDeath94's Avatar
Car: '87 Trans-Am
Engine: LB9 (305 TPI)
Axle/Gears: 3.42 or 3.73..figuring it out still
cam install...
What would happen if you just slapped the roller cam in on a late 80's 350 without dialing it in? Is it possible to get lucky and have everything just be ok even though it wasnt? Or would it always be kind of close, but just not correct?
Old Apr 8, 2006 | 03:24 PM
Vader's Avatar
The chances are very good that if all you did was align the timing marks on the crank and cam sprockets, the cam timing will be just fine.
Old Apr 8, 2006 | 03:37 PM
cyko83's Avatar
Car: 83 trans am
Engine: 5.7 V8
Transmission: 700R
cam
i have to agree as long as u have the dot on the crack sprocket at 12 o'clock and the cam sproket on 6 o'clock u should be fine but if ur puting a bigger cam the timing on the distributer will be different
o yea does any one know about oil pressure??
Old Apr 8, 2006 | 04:32 PM
Car: '87 Trans-Am
Thanks guys...I havent built a motor in about 5 years and Im a bit rusty on things. So occasionally I wake up screaming in the middle of the night panicing over something :-p I aligned the marks and its a stock(close enough) 350 roller cam. Just wanted to verify.
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
