Car died in traffic
Old Apr 9, 2006 | 01:07 PM
quisterio's Avatar
Car: 87' GTA
Engine: 350 L98 TPI
Transmission: 700-R4
Axle/Gears: 3.27 9-Bolt
Car died in traffic
Ok, yesterday my car just died on me pulling out in traffic (very scary experience) so, I had a whole lane of traffic about run into me,
I pulled out, and it died, I stopped, it started right back up, got enough power to go across the road and it immediately died again, I sat for a couple minutes, started it back up, and I got home with it.
This is only the 3rd time dying while out driving, what can be causing this?
Old Apr 9, 2006 | 01:11 PM
ThraxXx's Avatar
Car: 1988 Pontiac Trans Am
Engine: 5.0L Fuel Injection
Transmission: Automatic 4speed /w OVerdrive
When was the last time you did a tuneup on your car? If its been a while, then I would start there.
Old Apr 9, 2006 | 03:20 PM
BlkBird408's Avatar
Car: 89 Firebird
Engine: 408
Axle/Gears: 12 bolt/4.11
I agree with the tune up. could also be a faulty fuel pump or clogged fuel filter.
Old Apr 10, 2006 | 01:33 PM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
I would also check your IAC (Idle Air Control) sensor. If it is dirty, it will cause the car to surge and/or die. I found this out the hard way
Hope this helps!
Best of luck.
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
zeitghaist
Aug 18, 2015 07:33 AM
