Torque specs for a 305 motor?
Old Apr 9, 2006 | 05:27 PM
Crusin' 1980's's Avatar
Car: 1988 SC Camaro
Engine: 305 TBI
Transmission: 700-R4
Does anyone have information regarding the torque specs or tightening sequecne for rockers arms? Also, I have aftermarket 1.6 rockers, would the torque be the same as if they were stock?
Old Apr 9, 2006 | 05:32 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
you're still going to tighten to 0 preload, then 1/2 turn or so. So yea, same as stock. also rotate the motor over a few times by hand before you go to start it, just to make the sure pushrod doesn't hit the end of the slot in the heads.
Old Apr 9, 2006 | 05:38 PM
Car: 1988 SC Camaro
Engine: 305 TBI
Sorry to sound dumb about this, but I'm not exactly sure what 0 preload means...also, someone else told me that i should let the engine run for a while and warm up before i try to tighten the rockers...opps, i guess i forgot to mention that I'm doing this because one of my lifters is tapping and i think its because of a loose aftermarket rocker arm...
Old Apr 9, 2006 | 05:46 PM
Car: 1988 SC Camaro
Engine: 305 TBI
I need to figure out which one is tapping and tighten it a bit...
Old Apr 9, 2006 | 08:28 PM
Sonix's Avatar
Car: 1982 Trans-Am
use a stethoscope (the $15 will pay itself off very soon), and listen on your valve covers, it'll help you find it easiest.
that tapping sound can easily (EASILY) be mistaken with an exhaust leak.
basically, make sure your lifter is on the base circle, sure fire way to do this, is if your exhaust valve on a cylinder is open, then the intake is on the base circle. and vice versa. So when the lifter is on the base circle, grab your pushrod, and move it up and down, or rotate it, and tighten your lifter down, until you feel resistance in the pushrod (ie, the rocker is touching it), that's 0 preload, ie, no slack. Then add 1/2 turn.
jhawkeye
May 25, 2022 06:33 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
BlackphantomZ28
Aug 31, 2015 10:29 AM
86White_T/A305
Aug 17, 2015 12:16 AM
st.evel07
Aug 13, 2015 06:15 PM
