intake install
Old Apr 11, 2006 | 12:56 PM
adampousson's Avatar
Car: 91 firebird
Engine: 350 vortec heads
Transmission: t5
Axle/Gears: 3.08 open diff
intake install
can i fire up my motor right after i install my intake or should i let the rtv cure.ill just fire it for a few minutes.probably wont even warm it up.
Old Apr 11, 2006 | 02:40 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Really should have let the RTV cure before you put the intake on.
Old Apr 11, 2006 | 04:50 PM
ChevyGuy87's Avatar
Car: 2004 Wrangler Rubicon
Engine: 4.0
Transmission: NV3550
Axle/Gears: Dana 44s with 4.10 and air lockers
I've never let RTV cure before exposing it to fluids. In fact, every day when I do tranny or diff services the RTV has a whopping minute to cure until there is some sort of fluid behind it. No leaks yet.
Old Apr 11, 2006 | 07:42 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
The problem with the intake is the pressure, not necessarily the fluids. Most (probably all) motors have some "blowby" - this crankcase pressure will blow out the seal if the RTV hasn't dried and cured - I just finished my 4th intake install in as many months (kept having oil leaks), all because I wasn't letting the RTV cure enough.
This last time, I let it dry for 2 hours BEFORE I installed the intake. THEN, I let it set up overnight BEFORE I started the motor at all. That sucker finally sealed! BTW - I didn't use the stupid rubber china wall gaskets either.
I also heard to do like Stekman said, and let it dry BEFORE installing the inatke at all - but I also was told if you do this, to also add more RTV when installing intake, and tighten it down, THEN again wait overnight before starting car - a 2 day process basically.
LET IT DRY!
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
mdtoren
Aug 23, 2015 12:52 PM
bryan623
Aug 10, 2015 11:33 AM
