I need a new cam for my TPI- What is a good lopey low torque, daily drivable cam....
Old Apr 12, 2006 | 08:46 PM
indirocz28's Avatar
Car: 1986 IROC Z-28
Engine: Rebuilt Vortec Headded 358SB 9.5:1
Transmission: 700r4, corvette servo, Transgo kit
Axle/Gears: 3.23 POSI
Ok- I need a new cam- mine is junk lol!.. I am wanting to go with something that would be the equivalent of a "hot cam" and still give me low end torque and great power over what i had, as well as maintain daily driveability.. I was looking at a lunati hyd. flat tappet cam( b/c i already bought lunati hyd. flat tappet lifters)
The lunati specs are as follows:Brand: Lunati
Product Line: Lunati Hydraulic Flat Tappet Camshafts
Cam Style: Hydraulic flat tappet
Basic Operating RPM Range: 2,000-5,500 RPM
Intake Duration at 050 inch Lift: 224
Exhaust Duration at 050 inch Lift: 224
Duration at 050 inch Lift: 224 int./224 exh.
Advertised Intake Duration: 290
Advertised Exhaust Duration: 290
Advertised Duration: 290 int./290 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.460 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.460 in.
Valve Lift with Factory Rocker Arm Ratio: 0.460 int./0.460 exh. lift
Lobe Separation (degrees): 112
Intake Valve Lash: 0.000 in.
Exhaust Valve Lash: 0.000 in.
Would this be a good cam to go with, or does anyone have any other reccomendations?
I was also looking at this cam
Brand: Crane Cams
Product Line: Crane Z Series Hydraulic Flat Tappet Camshafts
Basic Operating RPM Range: 1,600-5,400 RPM
Intake Duration at 050 inch Lift: 212
Exhaust Duration at 050 inch Lift: 218
Duration at 050 inch Lift: 212 int./218 exh.
Advertised Intake Duration: 262
Advertised Exhaust Duration: 268
Advertised Duration: 262 int./268 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.446 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.459 in.
Valve Lift with Factory Rocker Arm Ratio: 0.446 int./0.459 exh. lift
Lobe Separation (degrees): 114
My engine specs are in my sig. w/a 9.5:1 compression ratio forged flat top pistons, Vortec Large port heads, High flow TPI stuff and what not..
From a previous post----
Quote:
Originally Posted by D's89IROCZ
I am not sure of the I/E ratio of them heads but , with most GM heads they have a weak exhaust so I would recomend a split pattern cam at the least, to make up for that bias.
You got the flow numbers on them ? :End Quote
No i dont but the heads are Jegs PN:809-12558060
Thanks everyone.. My current cam that is now wiped out is listed in my sig. If you want more info on that one here is the link to Crower-
Crower Cams & Equipment - Camshaft Specification Card
Old Apr 12, 2006 | 09:25 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
cc305 or cc306
Old Apr 12, 2006 | 09:36 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
I think those cams require a roller setup. Not sure if "lopey" and low end torque belong in the same sentence.
Old Apr 12, 2006 | 09:49 PM
indirocz28's Avatar
Car: 1986 IROC Z-28
Here is another cam i just found-
Brand: Competition Cams
Product Line: Competition Cams Xtreme Fuel Injected Camshafts
Basic Operating RPM Range: 1,500-5,500 RPM
Intake Duration at 050 inch Lift: 216
Exhaust Duration at 050 inch Lift: 223
Duration at 050 inch Lift: 216 int./223 exh.
Advertised Intake Duration: 260
Advertised Exhaust Duration: 272
Advertised Duration: 260 int./272 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.499 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.493 in.
Valve Lift with Factory Rocker Arm Ratio: 0.499 int./0.493 exh. lift
Lobe Separation (degrees): 113
Computer Controlled Compatible: Yes
Grind Number: 260XFI H13
Not trying to offend you my man, but if you would read the description of the cam it says right there they are Hyd. flat tappet.. And as far as the Lopey/ low end performance- you may be right . lol..
Anyway's Keep the info comeing everyone please!!!!
Originally Posted by Token
cc305 or cc306
Token- Where can i find this? I assume from the CC that its a CompCam's cam? And how well does it work in your car with your setup?
Thanks!
Last edited by indirocz28; Apr 12, 2006 at 09:52 PM. Reason: Automerged Doublepost
Old Apr 12, 2006 | 10:17 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
"TPI", "good", "lopey", "low torque" (assume you mean "low RPM torque"), and "daily drivable" cam don't belong in the same sentence together.
Can we assume it is a non-roller lifter block? If so, forget the cc cams mentioned.
Old Apr 12, 2006 | 10:26 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Old Apr 12, 2006 | 10:53 PM
Car: 1989 GTA
Engine: 369 TPI
I was refering to the CC305 and CC306 cams mentioned as being roller cams. Sorry for not being clearer. No offence taken.
Old Apr 12, 2006 | 11:28 PM
indirocz28's Avatar
Car: 1986 IROC Z-28
Ahh, i see- we are on the same block now.. lol
Right- not a roller lefter block,
Ok- well i can kinda figure out that much, but, here is what im looking for- i have one hell of a top end for that motor- the votec's, But i need more on the LOW and MID powerbands.. What one of these that i've listed on here be my best shot at obtaining that? Also please notice the differences in Lobe Separation Angles.. Thanks!!!
Last edited by indirocz28; Apr 12, 2006 at 11:32 PM. Reason: Automerged Doublepost
Old Apr 13, 2006 | 01:57 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I think that xfi cam you mentioned would be a good one. That's a lot of lift for little duration, 'specially for a FI type of cam, hmm, must have WILD ramp rates. I'll have to look into that more.
Old Apr 13, 2006 | 04:20 PM
indirocz28's Avatar
Car: 1986 IROC Z-28
Well- Here is the cam i ended up ordering-
CRN-113511 $109.88
Estimated Ship Date: 4/22/06
Warnings Application Warranty Show All
Brand: Crane Cams
The guys at summit said it would be a great cam for what i'm wanting...
I will be sure to let you know how it works out though...
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Infested
May 22, 2018 11:56 PM
camaro71633
Sep 1, 2015 10:24 AM
InfinityShade
Aug 22, 2015 08:00 PM
ezobens
Aug 19, 2015 10:29 PM
