cam/2.77 gear/400 sbc combo
Old Apr 15, 2006 | 10:28 AM
Tim Hunsinger's Avatar
Car: 91 RS,
Engine: 406ci
Axle/Gears: 2.77 9 bolt
Hi,
I'm putting together a Vortec head 400 small block chevy for my 91 RS. I am using a stock convertor, 700-r4 and a 2.77:1 posi 9-inch rear. The compression will depend on my pistons but I'm shooting for 9.3:1. I have a brand new Summit 214/224 cam with lsa of 112* and mid .400" lift. Stock tire size (about 26"). Also using edelbrock performer or RPM (not sure yet).
Now my question...will this cam be okay to use with this combo--particularily with the 2.77 rear? This is a daily driver/weekend goof-off car.
Thanks for ANY input on this combo.
Old Apr 15, 2006 | 08:35 PM
Mark 89Formula's Avatar
Since you're running a 400 I think you can pull it off. Might be just a little soft down low but ought to pull nicely once it's rolling.
Old Apr 15, 2006 | 10:52 PM
miami79's Avatar
Car: camaro
Engine: 377sb 400++hp
Transmission: tko 600
should work nicely with the 400 and that cr, i´d say rpm intake to match the cam and heads.
Old Apr 16, 2006 | 12:08 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Will work very well in your 400 with vortecs. i ran this cam in my 350 vortec motor and liked its easy street manors, good gas mileage and overall. performance. A good choice with your mild 2.77 gearing. I wouldn't go any bigger.
Old Apr 16, 2006 | 09:02 AM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
Motor will run good but the car will be a dog with the stock converter and those gears.
Old Apr 16, 2006 | 09:32 PM
Car: 91 RS,
Engine: 406ci
Thanks for the replys! I am going to keep one eye open for a 3.08 gear set or 3.27-3.42 rear to swap eventually. I just redid brakes on the 2.77 rear so I will use it for now. This cam sounds good for me then! I want to keep the car mellow for now since the wife uses it from time to time. When I look for a convertor, what rpm range would be good, and would RPM be better intake over Performer? Again, mostly a street/fun car. Lots of questions, just don't want to be disappointed.
Old Apr 16, 2006 | 10:15 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
yes use RPM over performer, the performer is a glorified stock intake that's shiny new and clean.
why that cam if I may ask? Seems pretty small for that 400 motor (even considering the gears), and i've heard pretty bad reviews about it. The price is right of course, but I don't think a cam is where you want to save $.
did you mean 9 bolt rear, or do you really have a 9 "?
Old Apr 16, 2006 | 10:37 PM
Car: 91 RS,
Engine: 406ci
Its a 9 bolt (B/W). In the past I have over cammed a few motors. I figured I'd be better off starting small and working up. I have a two-piece t-cover so changing cams should be pretty easy if I need to later. I've read that manufactors base the rpm levels on a 350 inch motor and that a larger motor can handle more. This makes all the choices a little more confusing for me. So performer RPM would still give me good low end?
Old Apr 16, 2006 | 10:51 PM
Sonix's Avatar
Car: 1982 Trans-Am
yes definately on the performer RPM. Remember, vortec style.
well not necessarily that the cam is too small duration wise, but the lift is kinda weenie for a given duration.... And you're right, the larger engine will eat up the cam and ask for more, it'll be like having a 204/214 in a 350, which is barely bigger than the stock cam, hence me saying it's kinda small.
if you just bought it, and can return it, might I suggest a compxe268?
Old Apr 16, 2006 | 11:36 PM
leeperryracing's Avatar
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
that cam looks like one you'd put in a 305...very tiny, if you have decent heads/intake on that 400, that cam is gonna choke the whole combo down
Old Apr 16, 2006 | 11:45 PM
F-BIRD'88's Avatar
woops
Old Apr 16, 2006 | 11:54 PM
F-BIRD'88's Avatar
it's very easy to be tempted to put a big cam in 'er.
With your mild rear gearing you have to think about what rpm you'll be using most of the time. Think about the rpm that you'll be at while cruising on hyway in OD. This cam is not like such and such and cam in a 305.
It is this cam, in a 400 vortec motor with 2.77 rear gearing. it will work fine. If you want a big cam, you'll want to change the rear gearing and converter as the rpm range will be higher. This cam is a good choice for your application.
I ran 13.00 times with this cam in my 350 vortec motor with a th700r4. gas mileage was good. I can see you running high 12's with sticky tires while still getting good daily cruising efficientcy. back and forth to work, road trips, etc.
Try it. Summer cruising looses its glamour fast if you have to stop in at every gas station along the way.
Old Apr 18, 2006 | 02:09 PM
Car: 91 RS,
Engine: 406ci
Thank you,
I'm getting ready to buy pistons. I will use either a 30cc or 22cc. The 30cc will give my combo 8.9:1 compression, while the 22cc piston yields 9.6:1.
Using the 214/224 cam with 112* LSA, how much power will be lost due to the lower compression? I'm worried that the higher compression pistons will cause spark knock. I'd like to stay with 112* LSA for somewhat better economy. Again, thanks for any feedback.
Old Apr 18, 2006 | 02:50 PM
ljnowell's Avatar
Originally Posted by Tim Hunsinger
Thank you,
You wont have any problems running 9.6:1. That is optimal really for that cam and a daily driver. I dont think that the 112* LSA will necessarily equal better economy. Lets face it, you are building a 400+ ci engine.
I agree with the above posts though, dont go bigger on the cam without saving money for gears and stall.
Old Apr 19, 2006 | 12:04 AM
F-BIRD'88's Avatar
YOu'll want the -22 cc dished pistons for your 400 with 64cc cylinder heads.
I used KB-168's Keith Black Hyper Federal mogul makes a -22cc piston too
Linson
Oct 24, 2025 02:00 PM
InfernalVortex
Apr 20, 2021 11:31 AM
gixxer92
May 18, 2017 11:20 AM
darwinprice
17
Oct 11, 2015 11:51 PM
Bradsaundry
Oct 7, 2015 04:35 PM
