Is my rocker adjustment gonna be off?
Car: 1992 Z28
Engine: 350 tpi
Transmission: 4L60
I adjusted my rockers by putting #1 at tdc which I thought tdc was in the middle of that tube on the timing tab but I found out the first notch next to the tube is tdc. anyway I adjusted the rockers like the book said but with a 1/2 turn instead of a whole turn. Is my rockers going to be not adjusted right? Or am I going to have to do it over?
Car: 1992 Z28
Engine: 350 tpi
Transmission: 4L60
Ok can anyone else confirm this? I just wan't to be sure because the car won't start and I wan't to rule that out. Thanks.
Car: 89 jaguar xjs convertable
Engine: 89 L98 5.7 TPI
Axle/Gears: 3.23 dana 44
I'm thinking with 7600 posts Apeiron probably has a pretty good idea what he's talking about..............
If anything your a little loose on your settings....if it caused you any issues they would be performance related and not cause a no start issue.....what did you do to the motor? Cam change etc............
Car: 1992 Z28
Engine: 350 tpi
Transmission: 4L60
I did head gaskets on it. I don't know if my timing light is screwy or what but sometimes I get the light to light and sometimes I don't. The timing light is almost new and I tried it on a running vehicle and it worked fine so I don't think its that. I replaced the rotor, cap, coil, and wires. I've always had a tough time starting it. I don't think the carb is adjusted right or something. I would run it for a while then it would be really hard to start or wouldn't start. I'd take out the plugs and they were carbon fouled. I'd clean them up and it would run ok for a while then same thing. Should I get the carb rebuilt? Also, what about that ignition? I don't understand it.
K I S S method.....keep it simple stu---....... you gotta have air fuel and spark...if it ran before it should run now. Check for fuel. Remember the carb is empty now....don't know what your set up is. You need to refill the bowl(s) of the carb with fuel and re prime the fuel line. You may have the dizz out 180 or just plain in wrong. Or...you have missed hooking up something. Unplug #1` wire and stick your finger in it while some one turns.....NO no no just kidding!! Start from the top. Pull #1 plug and roll motor over until it blows your finger off and check balancer and timing tap. Should be at 0*. Now verify your on compression stroke and re clock the dizz to point at #1 cyl. Now verify you have spark and start over
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Car: 1992 Z28
Engine: 350 tpi
Transmission: 4L60
There is only 2 ways you can put in a distibutor right? Because of the oil pump shaft I can only put it in 180 off or right on right? Well I tried the other way and it shot fire out the exhaust manifold. (I don't have the exhaust on yet.) So I put it back it tries to start it will fire but it won't start all the way. I'm really thinking the carb is screwed up.
Engine: 383 Carb
Transmission: 4L60
There are a lot of ways you can put the distributor in. It doesn't matter how it's in, as long as the rotor points to the cap terminal that's connected to the #1 plug wire when the engine is at TDC #1 firing.
Engine: 383 Carb
Transmission: 4L60
What were the valves doing at the time? With the timing marks lined up you could be at #1 TDC firing, or you could be at #6 TDC firing.
UltRoadWarrior9
Apr 28, 2020 10:39 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
tyeo098
Nov 30, 2015 06:27 PM
New2Chevy
Sep 28, 2015 12:35 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
