serpentine, alternator, valve cover clearance problem,need help asap.please
Old Apr 15, 2006 | 07:55 PM
anthony714's Avatar
ok,heres the deal.im upgrading my 400 block to a 1988 serpentine setup.i have all the accessories which came from the 88 serpentine setup including the brackets.im running the chevrolet black crinkle tall valve covers.for some reason i cant mount the ALTERNATOR W/O THE POSTIVE TERMINAL ON THE BACK OF THE ALTERNATOR HITTING THE VALVE COVER..HAS ANYONE COME ACROSS THIS BEFORE?THIS IS A ALL NEW SET UP SO I CANT COMPARE IT WITH ANYTHING.IM LEANING ON MY VALVE COVERS BEING A TAD OVER SIZED AND THATS WHAT IS CAUSING THE INTERFERENCE ISSUE.THERES NO OTHER WAY TO SPACE OR MOVE THE BRACKET AND OR ALTERNATOR WHICH IS WHY IM LEANIGN TOWARDS THE VALVE COVERS.ID HATE TO GET RID OF THE VALVE COVERS.ANYONE WIHT HELP AND /OR PICS PLEASE SEND ASAP.THIS IS DELAYING MY BUILD UP.PLEASE.........
Old Apr 15, 2006 | 08:08 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
did you try a longer belt and spacing the alternator away a little?
Old Apr 15, 2006 | 08:12 PM
anthony714's Avatar
no way to move to alternator.with the serp set up its mounted in 2 fixed holes so adjustability gone.i cant space the bracket towards the front either because that would throw the alt pulley out of line with the rest of the pullys.im really leaning towards new valve covers but would hate to have to replace them,i really like them.and i dont know if new ones will fix problem.i think the fact that they are "tall"covers might be screwing it up but i cant beleive im the only one who has tall valve covers on a early sbc with an early serp set up..please anyone help
Old Apr 15, 2006 | 08:15 PM
xpndbl3's Avatar
Car: 1984 Z28
dent the front of the valve cover then. the serp. setup i took off our 91 surburban allowed the alternator to be adjusted up or down probably 1/2" in height. otherwise you'll need to dent them up.
Old Apr 15, 2006 | 08:28 PM
anthony714's Avatar
kinda trying to avoid denting brand new valve covers
Old Apr 15, 2006 | 08:30 PM
xpndbl3's Avatar
Car: 1984 Z28
well if the brackets aren't adjustable like you stated, then there is really only one choice. ditch the serp. setup or ditch the valve covers or dent one or the other.
Old Apr 15, 2006 | 08:46 PM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
DON'T DENT THOSE COVERS!! Easy fix here. Remove the three screws that hold the back of the alternator to the front and rotate the stator ring and the back of the alternator 1/3rd of a turn counterclockwise viewed from behind. You will probably have to get a goofy socket to remove the screws. It will put the positive terminal about 11:30 o'clock viewed from behind and the plug at 7:00 o'clock.
... the stator ring is the band between the front half of the alternator and the back half. It must rotate with the back half.
Last edited by Supervisor42; Apr 15, 2006 at 08:49 PM. Reason: Automerged Doublepost
Old Apr 15, 2006 | 11:03 PM
xpndbl3's Avatar
Car: 1984 Z28
i tried telling him to rotate the alternator, but he said he couldn't...?? supervisor42 and I think alike on this
Old Aug 24, 2020 | 06:07 PM
11ellswray's Avatar
Car: 1986 Camaro Z28
Engine: 385" SBC
Transmission: built out 700r4
Axle/Gears: 4th gen, 373, LSD, GIRDLE
Re: serpentine, alternator, valve cover clearance problem,need help asap.please
NBrehm
Aug 25, 2015 11:49 PM
db057
Aug 22, 2015 08:17 PM
1985chevydude
Aug 20, 2015 12:29 AM
blackd-out z28
Aug 15, 2015 08:18 PM
mustangman65_79
Aug 8, 2015 01:18 AM
