Gas Leaking from Filler Neck!!
Old Apr 15, 2006 | 11:00 PM
fbird91ta's Avatar
Car: 1991 Trans Am
Transmission: TH700-R4
Axle/Gears: 2.72
I have a 91' Trans Am 305 TPI. I know they had a recall on the "filler neck" which entails the entire gas tank needs to be replaced. I replaced the gas tank and fuel pump (carter pump) and kept the rest original. When I fill up for gas or even 3/4 full, gas leaks out from the filler neck / filler tube down the side of my car and smells of gas, obviously. Why is this happening? The same problem happened with my old gas tank and now its happening with my new tank. Any Advice would be MOST appreciated.
Old Apr 16, 2006 | 06:36 AM
CEP89's Avatar
Car: 89' IROCZ
Engine: 5.7 L98
Check the gas cap seal, The vent tube to the carbon canister and the canister itself. Either your gas cap is not sealing or there is pressure being built up in the tank.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
TBRays98
Sep 6, 2015 05:05 PM
JHX
Aug 29, 2015 02:30 PM
