To Quench or not to Quench
Old Apr 16, 2006 | 07:16 PM
sstpres's Avatar
I'm completing a 408CI build-up and need some quidance. I'm using a Vortec iron heads w/64cc chambers, 2.02/1.6" valves and pocket ported. The pistons are dished (-12.5cc) and they are down in the hole .025".
I want the best chance of running 91octane pump gas. Would it be best to tighten up the piston to head distance to .040", increase the quench and increase the compression ratio to ~10.7? Or use a thicker head gasket lower the compression to ~10 and lose the quench?
I'm installing a solid roller with 249/254@.050, 107intake centerline and 111LSA.
Old Apr 16, 2006 | 07:29 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I'd really consider some different heads.
Old Apr 16, 2006 | 07:30 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
10.7 will be close to the limit on pump gas, but if it's in good tune and the cam has enough overlap to bleed off some of the cylinder pressure you might get away with it. Deck heights of -.025 plus a .040" gasket is a lot. Tightening it up will raise the compression but it will also be more resistant to detonation. Keep in mind you want to keep a minimun of .030" of piston to head clearance.
Old Apr 16, 2006 | 08:49 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
that's a very large cam, look up your dynamic compression ratio, and go with that, rather then the static. Remember, bigger cams need higher compression to work well. I think keeping your quench distance right is most important, you can always use sanding drums in the chamber and polish it, and gain a few cc's of volume. win win.
but yea, vortecs are (arguably) the best factory head made, but you're building something a lot more powerful then the factory put out. Why go with a giant SBC motor, a huge cam, and mediocre heads?
Old Apr 17, 2006 | 09:07 AM
sstpres's Avatar
Yeah. I know there are better heads for this application but I own these.
I was given the cam and had the short block.
They do flow pretty well:
Intake/Exhaust
.100 72/78
.200 128/135
.300 188/170
.400 231/183
.500 258/187
.600 260/191
My car is heavy (3650lbs). So I want to make a lot of torque down low. the smaller ports shold do that.
Old Apr 17, 2006 | 08:04 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Top ping or not to ping. Go with the quench. 10.7:1 may not be enough compression with that big of a cam. Like was posted above you need to check you dynamic compression ratio. Should be at least 8:1 for good performance on 91 octane. I bet you are not close.
Old Apr 18, 2006 | 10:19 AM
sstpres's Avatar
Yeah. I hear you. I'm going to proceed with a .015" head gasket and see how it goes.
Thanks for the help.
355tpipickup
Aug 27, 2015 08:13 AM
NWAsonoma
Aug 18, 2015 05:45 PM
JesasaurusRex
May 31, 2005 03:03 PM
TheMysticWizard
Oct 19, 2004 07:00 AM
Tom91Bird
Sep 1, 2003 05:23 PM
