reuse head, main, or rod bolts
Old Apr 17, 2006 | 02:51 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
just doing a simple bearing swap on the bottom end of a shortblock to have a motor this season, can i reuse head, main, and rod bolts?
Old Apr 17, 2006 | 02:52 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
As long as they're all in good shape, no corrosion, damaged threads or stretching.
Old Apr 17, 2006 | 05:55 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
main and rod bolts are pretty cheap though, if by season you mean racing season (which I assume you do) why not get entry level ARP parts? $17 for main bolts, $30 or so for rods
This is assuming you have stock bolts in there right now...
Old Apr 17, 2006 | 07:04 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Rods may need to be resized after new bolts, which could add considerably to the end cost.
The rod bolts are probably the most critical though. No other fastener in the engine takes as much abuse.
Old Apr 17, 2006 | 07:06 PM
ross's Avatar
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Axle/Gears: 9'' 4.10 gear
To replaice rod bolts you should have the rods reconed. And if you plan on making any power at all it will be agood idea. Mains are cheap but not nessary. Head bolts make sure you do not have the newer style torqe to yeild. And if you are going to use a power adder go ahed and put good bolts in. Good luck.
Old Apr 18, 2006 | 11:37 AM
xpndbl3's Avatar
Car: 1984 Z28
no this motor is just a 100k mile shortblock that i am ultimately having to toss in the car this season, because I spent all my motor money on a "fresh" motor only to find out that all the bearings were wiped down to copper and it's unusable. Definately wasn't too happy about that and the seller is long gone. Won't be putting a power adder on this stock shortblock, but it will allow me to drive it this year at least.
theurge
Aug 21, 2015 12:46 PM
LT1Formula
Aug 20, 2015 09:36 PM
86White_T/A305
Aug 17, 2015 12:16 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
