Header Bolts and Aluminum Heads....
Old Apr 17, 2006 | 09:08 PM
Pat Hall's Avatar
I tried posting this on the exhaust board with no replies. I know there's plenty of guys on here that are running headers with aluminum heads. I have a buddy putting headers on his aluminum head LT1 motor, and he's wanting to use blue loctite on the bolts. Is this a good idea with aluminum threads? My suggestion to him is to use anti-seize on the bolts and use a good set of lockwashers with the bolts. Anyone know which way is the best route to go when you have aluminum heads? Thanks.
Old Apr 17, 2006 | 09:15 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Loctite probably won't do much in that kind of heat. Stainless header bolts are a good idea, especially if the heads aren't helicoiled already.
Old Apr 17, 2006 | 11:29 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
how about safety wire? or use a stud with red loctite, and a stover nut.
Old Apr 17, 2006 | 11:42 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Studs aren't the most convenient thing to use with headers, and even if prevailing torque nuts don't back off, you'd need to make sure the studs themselves won't back out of the heads.
Old Apr 17, 2006 | 11:58 PM
eXesiv|83ta's Avatar
Car: 1983 Pontiac Trans AM
Engine: 355 chevy
Transmission: 700R4 Built
Axle/Gears: Built 10 bolt 3.73 gears
I've heard of people using green locktite on the bolts.
Old Apr 18, 2006 | 09:36 AM
Sonix's Avatar
Car: 1982 Trans-Am
green loctite??? what's that?
Old Apr 18, 2006 | 09:49 AM
I never mess around with Loctite. Especially not on header bolts. Cynoacrylate glue (Superglue) won't hold up to that kind of temperature.
Heli-Coil the heads if they aren't already, so the threads don't wear from the constant motion that headers produce; and use lockwashers, safety wire, locking bolts, etc. if you're concerned about the bolts loosening.
Studs nuts won't work any better than bolts, since the studs can back out of the casting the same as bolts. Doesn't matter how well the nut is locked onto the stud if the stud backs out.
Old Apr 18, 2006 | 04:23 PM
Rob Wade's Avatar
Car: 89 jaguar xjs convertable
Engine: 89 L98 5.7 TPI
Axle/Gears: 3.23 dana 44
Green loctite is for securing bushings into reamed holes.....not for bolts at all
Old Apr 18, 2006 | 06:29 PM
Pat Hall's Avatar
Never even bought green loctite before. I use the blue stuff(med. strength) if it's something I'll be undoing again later, and the red(high strength) for permanent stuff. The red is also great to use on heli-coil inserts when installing them. Either way, I told him I probably wouldn't use loctite anyways. I'm thinking either anti-seize on the threads and a good set of lockwashers, or nothing on the threads and lockwashers. Anti-seize helps prevent the threads from galling since it's two dissimilar metals you're dealing with(steel bolt/aluminum threads). When I worked at a garage, we always used a little anti-seize on the spark plug threads before installing them in any aluminum head. Heli-coils are by far the best thing to do to any aluminum thread, but I doubt he'll want to spend the money or the time to heli-coil all the bolt holes with the motor still in the car. Thanks for all the input guys!
Old Apr 18, 2006 | 08:24 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
you should always use antisieze on anything in alumnium. then just check the bolts every once in a while.
deracer
Apr 11, 2016 12:04 AM
LT1Formula
20
Nov 14, 2015 12:02 AM
Reddeath210
Oct 6, 2015 08:20 AM
Navy8125
Aug 22, 2015 07:13 PM
