oil psi
Car: 1984 Pontiac Trans Am
Axle/Gears: 9 bolt posi 3.27
hot or cold, i thought it was my gauge, before i rebuilt it and put the high flow pump in it i had about 40 at idle and 60 driving around
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
I doubt its actually bad for the motor, but I doubt your getting any extra benefit from it being that high.
alright, i justed wanted to know if it was normal for a high volume pump to be pushing that much, i only figured it would go up to 70 psi and give me better protection in the higher rpms
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
if by "better" you mean robbing you of 10-15hp then sure. you don't need that much oil pressure ever though.
Car: 1983 G20 Chevy
Transmission: 4L60
The high volume pumps are really setup for trucks. They get very heavy loading at lower rpms and often get very heat soaked. The HV pump gives more output at lower engine speeds where trucks benifit from it. I feel for a F-body the high volume pump is almost a waste. In a truck, it is a great upgrade.
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
well i'll run it and when i get some time i'll pull the engine back out and change it back to the stock
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
