How To: Compression test
Old Apr 19, 2006 | 01:51 PM
DocHoliday's Avatar
Car: Red 1984 Z-28
Engine: 4.8 LS
I was hoping someone here could give me a detailed explanation on how to perform a compression test. Or give me a link to a VERY detailed article on how to do one. Please keep in mind that I have never done a test like this before, and I am not taking it to a mechanic so I can learn as much as I can about my engine. Thank you in advance.
Also, I wanted to know exactly what numbers I need to write down when I do the test and which ones go with the different parts they corospond with.
For Example: If a number is low, this is what you need to fix. If its high, this is what you need to do. Etc.
Thanks!
DH
Old Apr 19, 2006 | 02:05 PM
Charge the battery as charged as you can get it; pull all the plugs; block the throttle wide open; unplug the 12V to the dist, and the plug to the fuel injectors. Hook compression gauge to each cyl; spin motor, maybe 5 compressions on each cyl.
Ideally you want all cyls to come up to pressure in about the same # of pumps, and all the numbers to be within 10psi or so of each other. The actual # itself isn't as important, as how consistent they are. Expect numbers in the 160-190 psi range for a typical factory motor in good shape.
Old Apr 19, 2006 | 02:40 PM
bobdole369's Avatar
Car: 1989 Firebird
Engine: 2.8L V6 MPFI
Transmission: Beat to heck 700R4
Most importantly - screw the compression gauge into the same hole you just took a spark plug out of....
cylinders are numbered starting with the passenger front, continuing clockwise around the motor, 123456 (driver front is #6)
Old Apr 19, 2006 | 02:53 PM
pull all the plugs
Do this first, before putting the gauge in any of them.
Elephantismo
Feb 13, 2019 12:51 AM
ramicio
Sep 28, 2015 01:18 PM
RedLeader289
Sep 23, 2015 06:50 AM
reactor60
Sep 22, 2015 01:44 PM
WhteRbt
Sep 21, 2015 09:48 AM
