Anyone running .488+ lift on 416 heads?
Old Apr 19, 2006 | 11:22 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Just wondering if anyones running a .488 or similar lift with the +.050 locks?
A stock 416 casting running '.438' shouldnt be a problem. right?
Old Apr 20, 2006 | 08:54 AM
rustybluebird's Avatar
Car: 87 Firebird
Engine: 350, 416's, 230/230 cam, torkerII, q-jet
I' running .480 with an installed height of 1.750.
Old Apr 20, 2006 | 12:19 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
i'm going to be running .535" with aftermarket retainers, locks, etc, positive seals and 1.75" installed height.
You're going to use the 416 heads after all eh? those AFR's didn't fit the budget?
Old Apr 20, 2006 | 12:38 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
No, no AFR's yet
Have to save a few bucks for the trip to edmonton next month and this motor needs to get finished, pedal biking my **** to work every day sucks!
Im going to try and get as much of this as i can while im in edmonton, probably save alot of money!
But you have had the guides machined down on your heads have you not?
I cannot easily attain the tool to knock them down a bit and definately not going to put the money for shipping and machining into these heads...
Old Apr 20, 2006 | 01:10 PM
Sonix's Avatar
Car: 1982 Trans-Am
I'm not sure if my guides were lowered, my machine shop just said they put on positive valve seals, they didn't charge me for machining, so I can only assume they didn't.....
I also made it very clear, .535" lift, make sure it's ok. He said i'm fine, so....
Frozer!!!
Jan 19, 2024 04:55 PM
midge54
Dec 27, 2019 04:14 PM
theshackle
Mar 5, 2017 06:37 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
anesthes
Aug 8, 2015 09:37 PM
