Cast core roller cam & distributor gear
Old Apr 22, 2006 | 10:04 PM
smoktire's Avatar
Car: 88 camaro
Engine: L69 305
Transmission: TH350 3000stall
With a cast core solid roller cam do i need to run a bronze distributor gear or the stock one is ok Cam is Comp cams 12-772-8
Old Apr 23, 2006 | 09:38 AM
smoktire's Avatar
Car: 88 camaro
Engine: L69 305
No one knows !?
Old Apr 25, 2006 | 11:01 PM
SaintedCorrupt's Avatar
Car: '85 TA
Engine: Carb'd 350, ported 416s
Transmission: retrofitted T5
Axle/Gears: 3.42 7.62" 10-bolt, locker
i believe the reason for the bronze gear is so that if they decide to start disintegrating, you chew up the gear on the dizzy rather than the cam.
Old May 30, 2006 | 08:14 AM
smoktire's Avatar
Car: 88 camaro
Engine: L69 305
Just call comp cams and they said that cams finishing with a 8 like 12-772-8 are cast and they can be used with the stock distributor gear & fuel pump push rod so no need for the bronze thing.
Old May 30, 2006 | 08:45 AM
B Rhodes's Avatar
Car: 91 B4C
I agrere call comp cams. sometimes the dist gears are pressed on and are different material than the cam. On my roller cam they asked for a nitrided dist gear for best results.
Oops didnt read carefully enough I see you called them
junkcltr
Aug 2, 2019 11:12 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
camaro71633
Sep 1, 2015 10:24 AM
anesthes
Aug 8, 2015 09:37 PM
