Starter Problems
Old Apr 23, 2006 | 11:45 AM
tbarnard2's Avatar
Starter Problems
I am sick of this starter problem it has been going on for about a month now. I installed a new starter that just wont crank the car. the battery is good, the wires are correct, but when I try to crank, the starter grabs the flywheel, and all I hear is grinding, the starter grabs the flywheel, and slightly spins it , but it slips off, i have tried shimming, and all the bolts are correct.
Old Apr 23, 2006 | 08:57 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
Is there a possibility you are useing the wrong 168( not sure if this is the other amount of teeth) tooth flywheels with a 153 tooth starter ? You may have to take the shims out. You possibly have it too far away from engageing right.
Old Apr 24, 2006 | 12:12 AM
tbarnard2's Avatar
Move starter closer
I was reading an article on starter shiming, and it said if you shim both bolts then you (INCREASE the CLEARANCE). if you shim the inside bolt(IT DECREASES THE CLEARANCE) and if you shim the outside bolt(IT GIVES A LARGE INCREASE) with that said, should I shim the inside, to decrease the clearance.
Old Apr 24, 2006 | 03:41 AM
waldershrek's Avatar
Car: 85 Z28
Engine: 383 Stroker
Transmission: 700-R4
I believe so. It sounds like your starter gear is not matching with the flywheel. Are you sure that you have the right amount of teeth on the flywheel? If so then the shimming must be off.
Spyder_TheGamer
Dec 25, 2015 05:07 PM
5spdcamaro
Aug 28, 2015 02:12 AM
92camaroJoe
Aug 13, 2015 06:07 AM
milk
Aug 10, 2015 06:26 PM
