help with a 91
Old Apr 23, 2006 | 02:10 PM
kjvail1204's Avatar
help with a 91
i have recently purchased a 91 camaro 305 TBI. I changed, plugs, wires, cap, igniton pickup, ignition module, fule filter, pvc.
i am having a problem with it when the throttle was being applied. At both idle and WOT the car seems fine but when driving it or even in park when i increase the throttle the engine begins to chugg and shudder then when i let off the gas the car almost cuts out any suggestions what this might be.
Old Apr 24, 2006 | 10:03 AM
Crall13's Avatar
Car: 92 Formula
Engine: 5.7 L
Try checking your exhaust, if your cats/muffler are cloged then your not getting propper air flow. I had a similar problem till I replaced my cats.
Old Apr 24, 2006 | 10:10 AM
sully91rs's Avatar
Car: 91 RS, 95 Z28
Engine: 305 tbi, 350 lt1
Transmission: 4l60, 4l60e
Axle/Gears: monsterous 2.73s in both
Any Service Engine Soon light?
Old Apr 24, 2006 | 06:50 PM
kjvail1204's Avatar
cat it gutted and i cut the exhaust out so that its a straight pipe to see if that was the problem, and no there are no check engine lights on could it be knock sensor
Old Apr 24, 2006 | 07:38 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Look for broken/missing vacuum lines - vacuum can do terrible things.
Old Apr 25, 2006 | 10:15 AM
kjvail1204's Avatar
yeah probly shoud go about changing all of those they are lookng kindda rough ill start there, you know anyone that has a tensioner pulley, i broke mine off my 88 yesterday
Old Apr 25, 2006 | 10:21 AM
Crall13's Avatar
Car: 92 Formula
Engine: 5.7 L
I believe kthat you can get one from Autozone's Rent-a-tool
Old Apr 25, 2006 | 10:24 AM
kjvail1204's Avatar
a vaccume tester you mean
Old Apr 25, 2006 | 06:49 PM
Car: 1992 RS
Engine: Carbed 350
Autozone shows both a seperate pulley and the tensioner assembly available - Pulley alone in stock most stores $19.99 - Tensioner Assembly and order item $51.99 - probaly can order at local store and get in a day or 2 tops, as they have warehouses everywhere.
I did a search on their sire for Idler Pulley.
The vacuum lines can all be replaced with hoses the right size - the plastic lines impossible to get without yanking out of boneyard. Just be careful with the one running into the firewall at the pass side - it's the one you don't want to have to reroute, as it's tangled with all the wire harness (it runs vacuum lines to your A/C & heater controls).
Old Apr 26, 2006 | 08:29 PM
kjvail1204's Avatar
if the heather controls are not hooked up do youthink that could be my vacum problem. I dont have them hooked to the control unit in the dash
Old Apr 26, 2006 | 09:35 PM
sully91rs's Avatar
Car: 91 RS, 95 Z28
Definetly try plugging that line. I have never tried unplugging the heater vacuum line and seeing the results, but it is just like any other vacuum line. PLug it.
