1.5" or 1.52" Roller Rockers
Car: 1992 Camaro Z28
Engine: 5.7 LT1
Transmission: 4L60
Axle/Gears: 3.23's
Im using stock L98 heads (ported) and I want to use either 1.5 or 1.52 ratio roller rockers. Im not using the 1.6 because the head requires some modification. So out of 1.5 or 1.52 wich will work best??
Received 1,704 Likes
No significant difference.... a little over 1% more valve lift, is all.... so, something like .517", instead of .510", is all you'll get. I doubt you'd be able to tell the difference even on a dyno.
Engine: 5.7 LT1
Transmission: 4L60
Axle/Gears: 3.23's
Ok thanks, now I have some clarity to this. So I guess I'll just go with the 1.52's the comp ones are I believe the same price. So what the hell, it can only help.
Car: 85 iroc-z
Engine: blown 350
Axle/Gears: 4.10
they not only give you a little more lift they also open the valve a little faster
making the cam have a little more duration in the upper lift erea of the lobes. not to step on eny ones toes but you will see more power.
KO1
16
10-15-2015 05:00 PM
