Are These Cam Specs Good?
Old Apr 24, 2006 | 06:31 PM
92KRVZ28's Avatar
Car: 1992 25th Anniversary White W/ Red
Engine: Procharged 383CI/ Soon LS2 Turbo
Transmission: Manual 700R4
Axle/Gears: 4:11/Auburn Posi/Moser Axle
I got my custom grind today how do these specs sound?
Gross Valve Lift: .502 intake, .510 exhaust
Duration at .006 275 intake, 281 exhaust
specs @ 108 Intake Center Line
Duration at .050 224, 230
Lobe Lift .335, .340
Lobe Seperation 112.0
Sound Like a nice setup for my 383???i couldnt go too insane because it would hit the rods
Old Apr 24, 2006 | 07:15 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Sounds like a nice street cam for a 383, should be very torquey. You didnt say anything else about the engine though... what kind of induction? Whats the intended use?
Old Apr 24, 2006 | 08:36 PM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
I went one step below you and I wished I would have gone to the 224/230...it would have made a big difference I think. I want to hear some sound clips when you get it together.
Old Apr 24, 2006 | 09:27 PM
92KRVZ28's Avatar
the setup is 11.0:1 compression and right now its stock intake but the cam is setup for the holley stealth ram which im getting asap 58mm tb havent figured out the injectors yet, custom ram air intake.
Old Apr 24, 2006 | 09:30 PM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
I have the 32 lb injectors in mine and they are good for a little bit more.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
camaro71633
Sep 1, 2015 10:24 AM
cstrobel65
Aug 15, 2015 10:19 AM
TreDeClaw
Aug 14, 2015 06:58 PM
Fronzizzle
Aug 9, 2015 01:15 PM
