roller rocker problem,need a little help
Old Apr 24, 2006 | 08:21 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
hey guys ,i hope im in the right spot.i have checked the search and not found this problem so i hope someone can help.i have a 5.7 L-98 with L-t4 production cam,alluminum corvette L-98 heads casting number 113.All of these parts, entire engine included, are brand new and never been run.while im installing my 1.6 roller rockers(cat stainless steel)they appear to be angeled to the side away from each other at the spring side.the man thats helping me build the motor says he has seen it before but he doesnt like it.its almost like the giudeplates slot where the pushrod comes through is pushing it to the side a little.I am useing hardened push rods.I have a lot of time and money,well a lot of money for my budget,invested and i dont want to screw anything up.Any suggestions?thanks
Old Apr 25, 2006 | 09:53 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
you've got guide plates, are the rockers self aligning? do they have little "humps" on either side of where the pushrod pushes on the rocker?
Old Apr 25, 2006 | 04:13 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
they are non self alligning.Is there some kinda stud washer you could put under the stud to help line them up
Old Apr 25, 2006 | 09:52 PM
SaintedCorrupt's Avatar
Car: '85 TA
Engine: Carb'd 350, ported 416s
Transmission: retrofitted T5
Axle/Gears: 3.42 7.62" 10-bolt, locker
IIRC, L98 heads are supposed to align the pushrod. The guideplate and the alignment holes may be interfearing with each other. Check to see if the pushrod is rubbing at the head where it passes through.
Old Apr 26, 2006 | 07:55 AM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
they are like the ZZ-4 heads and had them machined for guid plates
Mickeyruder
Sep 2, 2015 02:45 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
LT1Formula
Aug 20, 2015 09:36 PM
Dialed_In
Aug 20, 2015 01:45 PM
IrocZ'85
Aug 17, 2015 06:24 PM
