To buy or not to buy: march pulleys
Car: 82Z28
Ive read several different opinions on these are they really gonna give me any kind of gains or are they just a waste of money?
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
I've got them on a bigblock,because I had no pulleys or brackets for it.They aren't much higher than stock stuff new.That said,you won't realize any noticable performance gains from pulleys.There are better places to spend that kinda dough,cause we all know March stuff ain't cheap.
Car: 82Z28
yup they are pretty high but thatll do thanks for the reply I think Ill spend the funds elsewhere on the car
thanks
thanks
Car: 85 Z28
Engine: 383 Stroker
Transmission: 700-R4
I think the only way I would buy pulleys was if I had done everything to my car and was looking for the last little gains. Otherwise, I there is way better places to spend that kind of money!
Car: 1989 Camaro RS
Engine: Modified 350 TPI
Transmission: Modified 700 R4
Axle/Gears: Posi 3.42
I have a set on my 305 L03. If you do not want to get inside the engine and make major mods, just do bolt ons then. Thats what I did. I noticed a difference with these pulleys. I recommend them, I swapping in a 350 soon ao I'll transfer them to that engine when I do.
Car: 89 Iroc
Transmission: automatic
Axle/Gears: 373
pullys
i have the march pullys, and did not notice any differince. however like most aftermarket stuff they do look much better then stock, and built to last. if i had to id buy them again
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
I did not notice any gains, but I did not buy them for that. I just think that they look nice.
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
I would say only use them as a last resort 'get all the HP you can' type of thing.
If you like your alternator to put out a bit of power at low RPMs dont get them.
If you like power steering at low RPMs dont get them.
If you like the bling or if you want to get .001 off your ET then they are for you!
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
I agree with the above and the fact that there are better things to invest in.
I know I went with as much drive speed as possible when I got my CV's.
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
