Lift Calculator please?
Old Apr 26, 2006 | 03:57 PM
izcain's Avatar
Car: 1983 Camaro Z28
Engine: 584
Transmission: TSI Glide
Axle/Gears: Quick performance 9 inch
Does anyone know of a calculator on the net or something where you can input the specs of your camshaft and have it tell you what the lift will be if you up rocker ratios from like 1.5 to 1.6 and such?
I'm lookin to up the lift with a ratio swap but lost the equations that help you determine the lift and such.
Old Apr 26, 2006 | 04:23 PM
Use a regular calculator.
For SBC, the stock rocker ratio is 1.5.
If you're given the "theoretical valve lift", divide by 1.5 to get the lobe lift.
To figure out the lift with 1.6 rockers, mulitply the lobe lift by 1.6.
Or if you know the lift with 1.5 rockers, mulitply by 1.6/1.5 which is 1.066667, to get the new valve lift with 1.5 rockers.
Old Apr 26, 2006 | 05:04 PM
Vader's Avatar
Don't forget to calculate the slight increase in duration (at the valve) while your calculator is handy. You'll need some ramp data, or need to presume some data from the advertised duration, duration at 0.050" lifts, and know a little about the lift@° of the lobe.
You could try plugging some numbers into this, but it's not perfect:
Engine Calculator.xls
PurelyPMD
May 5, 2016 04:57 PM
Rousseau92maro
Feb 1, 2016 05:12 PM
mr z28
Exterior Parts for Sale
Dec 14, 2015 05:14 PM
