Ok to Zip Tie plug wires?
Old Apr 23, 2006 | 10:30 PM
Crusin' 1980's's Avatar
Car: 1988 SC Camaro
Engine: 305 TBI
Transmission: 700-R4
I gently zip tied my plug wires together and routed them along the side and backside of the motor, is that ok? They're 8mm Taylor wires...
Old Apr 23, 2006 | 10:34 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
Yes and no. They should be fine in the time being, but they definitely aren't supposed to even touch eachother. Go get some wire looms.
btw are those coated 2055s?
Old Apr 23, 2006 | 10:36 PM
hotshotcamaro's Avatar
Car: 89 camaro RS
i definatly agree, i wouldn;t have them directly touching each other, i would go get a set of wire seperators or something to keep them apart
Old Apr 23, 2006 | 10:53 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
I've used zip ties for years and years... BUT.. you should have the one around them all loose, then ziptie the ziptie in between each wire, then tighten the original and trim. They don't look half bad and are easy as **** to do in the pits.
Old Apr 23, 2006 | 11:05 PM
Car: 89 camaro RS
the prob. i see is that they are rubbing each other now and will wear and start arcing to each other or other things
Old Apr 23, 2006 | 11:11 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
How will they rub if the zip tie(s) have them tight to eachother?
Old Apr 23, 2006 | 11:17 PM
gp423's Avatar
Car: 1989 Firebird Formula
Engine: LB9 305 tpi
Axle/Gears: open 2.73's baby!!
i use zipties, they work great, i hope it isnt a problem using them, i have had em ziped for about a month now and no problems yett, i use 8.5mm msd wires
Old Apr 24, 2006 | 08:12 AM
ljnowell's Avatar
As i have always been told, you do not want to wires that are consecutive in the firing order to be touching. Principles of induction tell us this is a bad thing.
Old Apr 24, 2006 | 08:56 AM
CrazyHawaiian's Avatar
Car: too many ...
I used a ziptie to keep a single OEM plug wire from touching the exhaust manifold once (think it was #8). It was kinda close but I was at the track and I wanted to have fun. At the end of the day I saw that it had melted off and damaged the wire. So I guess take the engine/exhaust heat into consideration when routing the wires and placing the ties and stuff.
Old Apr 24, 2006 | 09:21 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Having multiple wires zip tied together is not a good idea, you runa high chance of misfiring running it like that.
If plug wires have to touch each other they should run at a 90* angle to each other to reduce the risk of them doing whacky things to each other!
Old Apr 24, 2006 | 09:54 AM
oxiderush's Avatar
Car: 90 firebird
Engine: 350 5.7L
Transmission: Th-400 w/ Manual valve body
Axle/Gears: 4.10 Richmond gears
I've been told you can zip them with spacers. Try to follow along, i'm gonna get real confusing. take 2 wires and zip-tie around the 2, but leave it loose. then with a new tie, go around the 1'st tie, making the 1'st tie look like a figure 8 around the wires, being squeezed by the 2nd tie.Tighten them together, and it should hold the wires , but spaced apart the thickness of the 2nd tie. This meathod can be repeated to hold all of the wires.
On the other hand, you could spend $1.99 anywhere for cheepie wire seperators.
Old Apr 24, 2006 | 10:52 AM
Car: 1988 SC Camaro
Engine: 305 TBI
Yes, the headers are hooker 2055...I was hoping i could keep the wires tie wrapped b/c i thought they looked better, instead of being separated and taking up more room...i think I'll drive the car for a bit and see if there's any problems...there'a a chance that the tie wrap could melt due to the heat, so I'll keep my eyes on it
[IMG][/IMG]
[IMG][/IMG]
Last edited by Crusin' 1980's; Apr 24, 2006 at 10:57 AM. Reason: Automerged Doublepost
Old Apr 24, 2006 | 03:10 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
You don't want them all bundled together. I was a tad bored so I set this up:
Zip tie plug wires properly
I'll keep it up for a couple days. Pardon the background etc., I was lazy and just used my template. Quick and crude, but it gives you a better idea than my earlier crappy explanation.
Old Apr 24, 2006 | 03:59 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
red devil, you missing a few pictures on that site? Looks intriguing though.
Old Apr 24, 2006 | 04:20 PM
Car: 1988 SC Camaro
Engine: 305 TBI
I was not able to view any of your pictures...could you try it again?
shouldn't the thicker sheith (8mm) prevent signal interference? How thick would the wires have to be to tie them together?
Last edited by Crusin' 1980's; Apr 24, 2006 at 04:21 PM. Reason: Automerged Doublepost
Old Apr 24, 2006 | 04:51 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
Well after reading this thread, I have decided to go untie my wires.
Old Apr 24, 2006 | 04:52 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Ut-oh. How many pics came up? All five show on both my machines. IE or firefox? Dis inna good!!!
Sheeet! I just tried on firefox and nothing is coming up. IE works, I'll have to figure out why and try again.
The 8mm should provide adequate insulation, but they'll still rub and degrade the wire.
Try again, I think I got it.
Old Apr 24, 2006 | 05:28 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Working on firefox now thanks for the pics, looks good. I'll have to try it now
Old Apr 24, 2006 | 08:17 PM
92blue's Avatar
Former Sponsor
Car: 1992 Camaro RS
Engine: Yet another 350 TPI
Transmission: Borg Warner 6 spd
From my understanding, the problem isn't that they rub each other, its a matter of induced current.
Old Apr 24, 2006 | 08:58 PM
ljnowell's Avatar
DING! Whenever electricity passes through a conducter it induces a magnetic field around said conductor. When wires are running parallel to each other, the fields will interfere. Electromagnetic Interference can cause real problems. Use wire looms and keep them seperated.
Old Apr 24, 2006 | 10:05 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
With new wires you typically won't have an issue, it's after they age or the 'wrapping' deteriorated somehow, like rubbing, does the situation become exacerbated, otherwise you'd have misfiring/crossfiring motors from every half-assed install ever done... and I've seen some doozies! Not that there aren't issues, but it's not at all as drastic as people have read about.
Old Apr 25, 2006 | 10:27 AM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
I dont get it, I used zip ties to separate my wires and I have been driving like that for 5 months problem free.
Old Apr 25, 2006 | 03:57 PM
gp423's Avatar
Engine: LB9 305 tpi
i wish i would think about my phsycis class more often when working on the car, the wrapping the wires together can become a problem but is not huge in my oppinion, the magnetic field created by the current passing through the wire can mess with the field of another current in another wire, it shouldnt be a big problem because this field disipates as soon as the current is gone, since the wires you are wrapping together do not carry current at the same time, i dont think its too bad.
but i would change it if the engine sees a lot of higher rpm use because current is flowing more often in the wires and much closer together.
Old Apr 25, 2006 | 04:12 PM
Toehead's Avatar
exactly. The plugs only fire momentarily, and any induced current wont have a place to go (without jumping the plug gap). I'm not worried, until the induced current becomes strong enough to jump tha gap due to the age of the wires
Old Apr 25, 2006 | 04:25 PM
Sonix's Avatar
Car: 1982 Trans-Am
noise in your stereo is usually the big concern.
Old Apr 25, 2006 | 05:57 PM
Car: 1988 SC Camaro
Engine: 305 TBI
well, i haven't ran the car yet with the wires like that, so I'll keep my eye on it and see if there's any issues. If there is any problems, i will rewire them like the example that RED DEVIL provided in his post, Thanks.
Old Apr 25, 2006 | 05:58 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
also isn't the strength of the magnetic field in relation to the amount of current that runs through the system? now honestly how much current really flows through these wires?
Old Apr 25, 2006 | 07:29 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Cruisn, the main problem is the wires rubbing/shifting against each other. This will degrade the coating. Well, that and neatness. After spending time cutting and crimping wires, I like to finish the job with the zip method and matching colors, or reamed stock seperators.
As for the inductance issues... I'll give you one hint: Look at the firing order. There is one place where issues will arise before others.
Old Apr 26, 2006 | 12:25 PM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Transmission: THM700R4
Axle/Gears: 10 bolt, 3.23 non-LS
Does anyone care that this is really the distributor end and not the plug end?
Old Apr 26, 2006 | 12:30 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
I'm trying to play nice, I wasn't going to mention it... or the other one(s).
Old Apr 26, 2006 | 05:18 PM
Car: 1988 SC Camaro
Engine: 305 TBI
I didn't notice that...will it make a difference (besides looks)?
They're all in the same way...i put the red boots on the Distributer...is that a problem?
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
Infested
May 22, 2018 11:56 PM
djmarch
Aug 19, 2015 12:07 PM
