Need head torque sequence please....
Old Apr 29, 2006 | 09:42 PM
LVZ2881's Avatar
Car: 1988 IROC
Transmission: 5 speed
Axle/Gears: 3.08 Posi 10 Bolt w/ aluminum drums
I have searched the site, and my haynes manual is usless....
anyone have a link or a PDF file for the cylinder head torque sequence for an '88 305???
Old Apr 29, 2006 | 11:11 PM
dctrumpet's Avatar
Engine: 350 TBI W/all Ultimate TBI Mods
Transmission: 700R4 Stage 4
Axle/Gears: 9 Bolt 3.27
This should help you. This is the sequence for most sbc with 305/350 heads. Good luck. Torque them down to 68 lb. ft.
Attached Thumbnails Need head torque sequence please....-cylinder-torque-sequence.gif
Old Apr 29, 2006 | 11:21 PM
dctrumpet's Avatar
You will want to do this is 3 separate steps.
step 1 torque to 22 ft. lbs
step 2 torque to 45 ft. lbs
step 3 torque to 68 ft. lbs
Old Apr 30, 2006 | 10:56 AM
iroczracer07's Avatar
Car: 1989 Camaro
Engine: 350 but it's torn down right now.
Axle/Gears: I'm working on it,lol.
dctrumpet.
Old Apr 30, 2006 | 11:15 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
tightening in stages is definitely a good idea, should at least do it in two stages, after first tightening a little with 3/8" drive
after years of doing head jobs ive got it down to where i just start in the middle of the head and go around and around in a bigger and bigger circle with the bolts until im at the ends of the head
in which is really the whole point of the sequence
ive never had any problem ever with any head job ive ever done
also i always use plumbers pipe thread dope in a can on a brush for the bolt threads, after i chase the deck head bolt holes with a thread chaser and wash and dry the bolts
the pipe thread dope is good to 500 degrees and also lubes them and doesnt dry
so its perfect stuff for this i use it on intake bolts too, it keeps the oil from traveling up the bolts in which is a very common occurance on chevy engines especially
Old Apr 30, 2006 | 12:08 PM
TekViper's Avatar
Car: 1990 Pontiac Firebird
Engine: 3.1L v6
Transmission: Automatic
Be careful with putting anything on the threads of head bolts unless it is called for. The teflon paste will change the friction of the bolts going into the head and will let the bolt thread in more before your torque wrench clicks, changing the final torque.
deracer
Apr 11, 2016 12:04 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
gixxer92
Sep 1, 2015 04:32 PM
86White_T/A305
Aug 17, 2015 12:16 AM
