Oil pan problem.... Pics Needed...
Old Apr 30, 2006 | 04:17 PM
12SecondTA's Avatar
Car: 85' TA
Engine: 355 Carbed
Transmission: Built 700r4
I have a hedman header, and hedman y-pipe setup.
I have a pre-79 block, with driver side dipstick.
My problem is that when i tried to attach the y-pipe the oil pan was in the way, like a huge amount. i needed a good half an inch of clearance.
We tried beating the oil ban, used a 4lb hammer, and no clearance could be made, we feared we'd break the break.
What is the problem here, its the stock pan that came on this motor in 75. It doesn't have any fitment problems otherwise. Why is it hitting my oil pan?
Is there an oil pan i can buy thats cheap to work?
Are 82-92 f-body oil pans different in this fact?
Please post pics!
Very confused and on a time delema, need the car running..
Old Apr 30, 2006 | 04:27 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
I've got the heddman headers and y with a stock pan and no problems. What car did the oil pan you've got come from?
Old Apr 30, 2006 | 04:46 PM
12SecondTA's Avatar
Car: 85' TA
Engine: 355 Carbed
70's camaro...
big starter, big flexplate, fortunately, i had few issues with that grinded metal from the starter to make them fit...
My oil pan, it just felt like i'd be brekaing the metal if i hit it much harder, Might split the metal...
Old Apr 30, 2006 | 06:15 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
which headers?
I have the 68470's I think, stock pan on a '78 block I believe. Just lowering it into the bay, (many clearance issues!), but the oilpan/headers aren't an issue....
you don't have the headers swapped on opposite sides eh?
Old Apr 30, 2006 | 07:12 PM
12SecondTA's Avatar
Car: 85' TA
Engine: 355 Carbed
Originally Posted by Sonix
which headers?
pretty sure having a header on thw wrong side is impossible.
my engine fit in there very easily, headers were bolted onto the block and all.
I think i may have found a cure, but my fingers are still crossed.
I'll be letting ya'll know..
my86bird
Oct 23, 2015 12:20 PM
camaro71633
Sep 3, 2015 03:56 AM
downsouthboy
Aug 29, 2015 11:29 AM
Navy8125
Aug 21, 2015 09:32 AM
MY87LT
Aug 17, 2015 08:43 AM
