new heads
Old May 2, 2006 | 11:12 AM
redbird8628's Avatar
Car: 1986 Firebird
Engine: 3.4 outa 95' bird
Axle/Gears: 3.42 open rear
new heads
i just got my new heads on this weekend and drove it for the first time tonight, noticed oil pressure is around 60 psi and there is a slight knock coming from the drivers side head, i may need to re adjust the valves, but with the est wire plugged in, it boggs bad at over half throttle. i didnt set the timing with a light, i had it rotated a little counter clockwise of where it normally sits to play it safe, also, my cooling fan kicks on as soon as i start the car, maybe i have my friendly code 15 again, will check codes tonight
Old May 2, 2006 | 12:16 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
that knocking isn;t a header leak is it ?
Old May 2, 2006 | 12:21 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Is it a knock or a tick?
Tick could be from improper lash, exhaust leaks or injectors if your EFI.
Knocks are usually from something worse like deto or a bearing.
Old May 10, 2006 | 08:33 PM
Car: 1986 Firebird
its gone now, it was on first start up, oil pressure is all good now, now just to figure out that timing problem
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
FormulasOnly
Sep 6, 2015 10:42 AM
z28guy134
Sep 1, 2015 11:50 PM
