A/C Removal
Old May 3, 2006 | 08:40 PM
floydian7889's Avatar
Car: 83' Firebird
Engine: Modified 305
Transmission: 700-R4
Axle/Gears: 4.11 gears
A/C Removal
I've got two different F-bodies that are at two different points of completion. One is a 86' Camaro that has everything attached...or as of now does. I plan on taking out the compressor, lines and the big box next to the blower motor housing. The second 3rd gen is an 83' Firebird..with just that stupid box still in the engine bay. My question is, what is that box housing called? And how do you remove it. I can see that it has a couple of bolts that attach it to the firewall....but is there some internal **** that i'm not aware of. Thanks!!!
Old May 3, 2006 | 10:18 PM
82_t/a_305's Avatar
Car: 1982 Trans Am
Engine: 305 H.0
Transmission: th350
A/C Removal
there is but it isnt attached to the box that surrounds it , i took mine out and it was not hard at all , all thats inside is where the lines come into the box (i dont remeber with the part is called) but it just lifts out of place
Old May 3, 2006 | 11:01 PM
Car: 83' Firebird
so not too much to worry about then for the '83 Firebird....any other advice about the '86
Old May 3, 2006 | 11:40 PM
82_t/a_305's Avatar
Car: 1982 Trans Am
Engine: 305 H.0
Transmission: th350
A/C Removal
should be the same as far as i know
Old May 3, 2006 | 11:44 PM
MavViper's Avatar
From what I remember you need to undo the bolts that attach it from the engine bay and then there are a few that are inside under the dash? I don't quite remember as I was taking off a master cylinder when a buddy of mine was taking it off. It's not that hard to get out though
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Ironhead38
Sep 7, 2015 02:26 PM
85Special
Sep 3, 2015 04:21 PM
