LT1/3rdgen spark plug changing
Old May 4, 2006 | 09:28 PM
TMoNeE's Avatar
Car: 87 Z28
Ok, Ive got an lt1 in my 87 z28... I changed the drivers side plugs (which took like an hour) it was a big pita but its done. I need other 3rdgen/lt1 guys to chime in... how did you do your passenger side... i can see no way other than to start taking a ton of stuff off...if any of you lt1 guys have advice, now is the time
Old May 5, 2006 | 11:07 AM
TMoNeE's Avatar
Car: 87 Z28
Not that you guys were any help, but I got em done, thanks
Old May 5, 2006 | 12:39 PM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
I know you said you were done, but the easiest way I found was to actually go in from UNDER the car. Keep that in mind for next time.
Old May 5, 2006 | 12:49 PM
Firebat's Avatar
I can get to all of mine from the top. I grinded down a spark plug socket and it works really well with a 3/4" rachet-wrench for getting into those hard to reach places.
Old May 5, 2006 | 01:15 PM
TMoNeE's Avatar
Car: 87 Z28
I have one of those go thru sockets that i used, its about an inch long total.. its perfect for this... drivers side all from the top, passenger side 1 from the top, 3 from the bottom.
eightsixseven
Dec 16, 2024 01:50 PM
evilstuie
Feb 28, 2016 03:33 PM
Red iroc-z 305
Sep 30, 2015 05:22 PM
g.l.mos
Aug 22, 2015 12:02 AM
