speed pro or no
Old May 4, 2006 | 10:38 PM
joey aucoin's Avatar
Car: '92 camaro rs 25th ann.
Engine: 1979 350 carbed w / built heads
Transmission: th 350 2500 TCI stall
Axle/Gears: 4.11 Richmond
speed pro or no
I was just looking for any ones opinon on speed pro pistons . I have a 92 rs camaro w / a 355 , stock 76cc ( self ported heads ) , stock crank and rods . With the speed pro dome pistons (p.n. 844-8-kh618cp ) just hypereutectic w / moly rings . This combo will put me some where in the neighborhood of about 9.5:1 compresion . I don't mind that , I was just wondering about the quality of speed pro . Any one care to coment ? Thank you !
Old May 4, 2006 | 10:40 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Speed Pro is just fine. Are you sure you'd be at 9.5:1 with domes though?
Old May 4, 2006 | 10:46 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I run speed pro's and they have been good so far in my 383
Old May 4, 2006 | 10:57 PM
I am not 100% sure . That number was just figured up a few moments ago by a friend of mine and I . The heads are 76 cc but measured out to 81 cc using water .
Old May 4, 2006 | 11:00 PM
shaggy56's Avatar
Car: 71 Nova
Engine: Superramed 383, Topline heads
Axle/Gears: 8.2 posi 3.08
I got 9.62:1.
That was with a 76cc chamber and .015 steel shim.
9.14:1 with 81 cc chamber
I averaged a .025 deck above piston but that wont be accurate unless you measure.
what kind
I was just wondering what kind of speed pro ( w / what combo ) pistons you are using
Old May 4, 2006 | 11:02 PM
I was looking at trying to get any where beteen 9.5 to 10 so 9.62 that would be good too .
Old May 4, 2006 | 11:06 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Originally Posted by shaggy56
I got 9.62:1.
With a flat-top piston.
I got 9.62:1.
I have .038 above piston deck . I was wondering were your heads a true 76 cc .
---------- I have .038 above piston deck w/ the flat tops in the car right now.
Last edited by joey aucoin; May 4, 2006 at 11:19 PM. Reason: Automerged Doublepost
Old May 4, 2006 | 11:09 PM
shaggy56's Avatar
Car: 71 Nova
I was going off the data you provided. I looked up those pistons on the Federal Mogul website.
edit:Im sorry with the 81 cc heads I get 9.5:1 and a .015 shim gasket. I calculated wrong for the dome ccs
If it had been a true 76 cc then 10.03:1.
Old May 4, 2006 | 11:11 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I think by .038 he's thinking of quench.
Old May 4, 2006 | 11:50 PM
Irockz's Avatar
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
Speed Pro hypers are the only ones to use,IMHO.Much better quality that the KBs.
Old May 5, 2006 | 12:25 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
I dont know the number off hand but with a 5.7 Rod and a 3.75 stroke the 383 piston comes in around 10:4:1 with a 64 cc head. It has 2 valve relieves. I run the shortblock with a 219 cam and miniram. Plenty of track use and dyno runs and its all nice and good.
Old May 5, 2006 | 05:55 PM
I have 5.7 rods but only a 3.48 stock stroke . If I can get 9.5:1 I would be just fine with that . I was looking to use a comp 292 cam and I have 1.5 comp rollere rockers already . I know that may be too much cam . I was just going off of a combo my brother had and it worked out great for him ( 12.3 in a s10 ) . feel free to put in your two cents . Thanks for all the help.
Old May 6, 2006 | 01:26 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
might want to get your machinist to cc a chamber for you. I couldn't get a very accurate measurement on mine, but my machinist did a chamber or two for me while he had to do other work to the heads.
speed-pro hypers are good. Not a race only part (high $$), and not a cheapo factory replacement cast. Much cheaper than a KB piston, and IMHO, the same thing.
I've got the H345's in my motor.
the bigger the cam, (like a 292), the more CR you need to run well. I forget what the duration @ .050 is for that cam, but you do want to be close to 10:1. Are you considering milling the heads or decking the block? 81cc's just sounds huge to me. *IF* you had to get the block decked or the heads milled due to warped surfaces, might as well get them cut down a fair bit, get your moneys worth, then get flat top pistons.
Old May 6, 2006 | 09:34 AM
Hey man thanks for the info. I am currently looking into getting the heads milled , but my mechanic was showing me some dyno sheets that show going from a 9.9 to 10.5:1 is only about 8 HP . I dont know if they are 100% currect . I am still looking into it to find out more info . Thank you for you'r again for you'r help.
Old May 6, 2006 | 10:16 AM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
I just bought the Speed Pro forged pistons for my car. Look nice and came with the coated skirts. I think the Hypereutetics also come with the coated skirts for an extra bonus.
Old May 6, 2006 | 08:45 PM
What combo
What typ of set up are you using in the rest of the motor . I mean like heads, valves, cam ex.
Old May 6, 2006 | 09:59 PM
Car: 1989 GTA
Engine: 369 TPI
See signature. Fixing to go higher in the RWHP department.
F.I. 57 Belair
Aug 23, 2021 01:09 AM
Kenwood
Sep 11, 2015 12:50 PM
adelane
Sep 9, 2015 08:51 PM
Eric-86sc
Sep 7, 2015 02:10 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
