cam installation
Old May 7, 2006 | 11:05 AM
puntank4200's Avatar
Car: '88 Camaro
Engine: v6-173-2.8L
Transmission: Automatic
cam installation
I want to install a cam, but have a few questions first.
1)If the initial compression on my engine is bad, then is a cam a waste of money? (Haven't checked compression yet)
2)Can it be installed with the engine in?
3)Should I upgrade the rollers, springs and lifters while I'm at it?
4)What's a good cam for making a daily driver quicker out of the hole.
5) -Off topic- Can I replace the main bearings while engine is still in car?
Old May 7, 2006 | 11:24 AM
Irockz's Avatar
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
1)Yes
2)I've never done it,but I'm confident that it could be.
3)by rollers,I assume you mean either that it has a factory roller,in which case if they are in good shape,I'd reuse them.Or your referring to roller rockers,which are a good investment,but not a necessity in a mild performance engine.As far as springs go,I would reccomend a new set,properly matched to the cam.At the very least,pull the old ones off and check them out.
4)IMO,one of the small Comp. Xtreme Energy cams.You'll get a lot of different opinions on this one.
5)I suppose it might be possible,but I sure would hate to be the one to do it.
anesthes
Mar 10, 2016 10:35 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
theurge
Aug 21, 2015 12:46 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
drathaar907
Aug 6, 2015 04:20 PM
