FIGURE THIS ONE OUT !!!!!!!
Old May 7, 2006 | 07:40 PM
1989iroc5.7's Avatar
Car: 89 iroc
Engine: 5.7
Axle/Gears: 3:73
i dont know about this one!! my car will sit for a few hours i will start it but if i let it run a few minutes and shut it off it wont start again.It will crank but not start.If i squirt gas or carb cleaner in the throttle body it will start and continue to run.the vats is disabled and i do have a jet chip in it.It does still have spark when it wonts start it just seems to be the fuel. ANY IDEA'S ???
THIS JUST STARTED TODAY!!
Old May 7, 2006 | 08:21 PM
327???'s Avatar
Car: '82 Sport Coupe/'89 bird/'77 280z
Engine: 355/2.8/L28E(t)
Transmission: TH350/T5/4 spd
Axle/Gears: 3.73/3.42/3.54
one of my friends trucks did something similar, he just poured a can of injector cleaner in the tank and that fixed it.
Old May 7, 2006 | 10:12 PM
Car: 89 iroc
Engine: 5.7
Axle/Gears: 3:73
put injector cleaner in today. actually i tried the car tonight a minute ago and now it wont start at all. did not try with carb cleaner thought,will try tomorrow. i can hear the fuel pump running and after i start it with carb cleaner it runs great so i dont think its the fuel pump.
Old May 7, 2006 | 10:30 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
How about the fuel filter?
Old May 7, 2006 | 10:51 PM
85LB9Z28's Avatar
Ive got close to the same problem...
my 85 305 takes close to 7 - 10 seconds of cranking to start...
when its running its nice and smooth...
and before cranking i can hear the fuel pump and seems ok...
did a complete tune-up and it still does the same thing...
Im stumped... anyone.. please help!!!
Old May 8, 2006 | 06:15 AM
Car: 89 iroc
Engine: 5.7
Axle/Gears: 3:73
i changed the fuel filter around last tuesday, the funny thing with the old filter is that the guts had boken loose and where wiggling around in the housing.i was thinking maybe dirt cloged the injectors but like i said once its running its fine.
Old May 8, 2006 | 02:35 PM
85LB9Z28's Avatar
same here, when its running its fine...
its just all the cranking before starting...
anyone??? please???
Old May 8, 2006 | 03:44 PM
MikeDirntRulez's Avatar
Car: 1990 Camaro RS
Engine: 305 TBI (L03)
Transmission: 700R4 (MD8)
Axle/Gears: 2.73 Open (GU2)
*delete*
Old May 8, 2006 | 05:14 PM
Rob Wade's Avatar
Car: 89 jaguar xjs convertable
Engine: 89 L98 5.7 TPI
Axle/Gears: 3.23 dana 44
Check the fuel pressure.
Old May 8, 2006 | 06:46 PM
PROCHARGED's Avatar
Car: 1992 TRANSAM 1989 FORMULA 350
Engine: L-98 350
Transmission: FIRM SHIFTING 700-R4
YES!! Did you change the fuel filter???
Old May 8, 2006 | 06:47 PM
Car: 89 iroc
Engine: 5.7
Axle/Gears: 3:73
ill have to try that but if the pressure was low wouldnt the car run funny at wot?
Old May 8, 2006 | 07:03 PM
Rob Wade's Avatar
With low fuel pressure it would idle decent and cruise decent but would stumble when you crack the throttle (for lack of pressure) and probably fall on its face about 3000 rpm
Old May 8, 2006 | 07:29 PM
Car: 89 iroc
Engine: 5.7
Axle/Gears: 3:73
the car runs strong as long as it starts.It pulls hard to redline!
Old May 8, 2006 | 10:08 PM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
No one's mentioned the fuel pump relay? I'm shocked, replace it and your problem will probably be solved.
Old May 8, 2006 | 10:25 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
So long as his oil pressure switch is good the relay can die and all he should experience is a hard start (until he builds oil pressure), not a no start. Now if one has already failed and the other is on the way out....
Any codes? Have you pulled the plugs when it doesn't start? What do they look like? The times it does not start, is your security light on? These are tricky without the car at our fingertips.
Oh yea, it's an '89? Forgot to add... When you have the no start situation, for giggles, unplug the Maf and see if you can at least start it (albeit probably not running too well). If you get a winner there, swap out the MAF relays.
Old May 9, 2006 | 06:09 AM
85LB9Z28's Avatar
Originally Posted by MikeDirntRulez
*delete*
Thank you so much for your help!!!
Old May 9, 2006 | 11:42 AM
Car: 1990 Camaro RS
I posted something but realized it wasn't going to help much so I deleted it.
You can calm down now idiot.
Old May 9, 2006 | 11:54 AM
Car: 89 iroc
Engine: 5.7
Axle/Gears: 3:73
its not the securtiy thing cus its been disabled with a resister,so the sercurity light never comes on.i have not checked the plugs when it does it but i would think its a fuel related issue cus the car starts right up if i squirt alittle carb cleaner in the throttle body.after its running its fine.If i let the car sit for an hour or so and try it its fine and starts up.I just got this car about a month ago so i dont know to much about this tpi stuff.. sorry guys.
Old May 9, 2006 | 04:09 PM
battman's Avatar
Car: 87 GTA, 88 GTA, 92 TA, 72 RS SS
Engine: 350, 350, 305, 396
Transmission: T56, 700r4, 700r4, T56
Axle/Gears: 3.42, 3.23, 3.23, 3.73
Its the distributor, change out the pickup coil and the ignition module and it will fix it. I've fixed three tpi cars with starting problems just like yours by rebuilding the dist.
Old May 9, 2006 | 05:42 PM
Car: 89 iroc
Engine: 5.7
Axle/Gears: 3:73
Ill try that .
sheachopper
Jul 31, 2019 11:27 AM
RedLeader289
May 28, 2019 01:47 PM
mrbird
Oct 20, 2015 03:43 AM
aaron7
Sep 30, 2015 09:15 AM
Zell1luk
Sep 29, 2015 10:36 AM
