Ring sizes on stock l98 5.7 block?
Old May 8, 2006 | 01:47 PM
vortech35091RS's Avatar
Car: 1991 camaro RS
Engine: 350,vortech heads,zz4 cam,3:73 posi trac,edelbrock carb,wiend stealth intake,raven mufflers,hooker supercomp shorty headers and y-pipe.
Transmission: th700r4
I'm in a bit of trouble I just bought a re-ring kit. I kept the cylinderwalls and everything stock, I didn't bore or any of that. And the rings I ordered (I ordered Standard size) and the rings went in fine, EXECPT the LOWER COMPRESSION ring. So I'm going to call the company that I bought them off of and re-order the rings I will need, only I don't know what the size on the lower compression ring is? Would any of you happen to know the size on the stock L98 piston? Thanks
Old May 8, 2006 | 05:20 PM
Rob Wade's Avatar
Car: 89 jaguar xjs convertable
Engine: 89 L98 5.7 TPI
Axle/Gears: 3.23 dana 44
4.0 is a standard 350 bore size
Old May 8, 2006 | 05:58 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
have you ever put on rings before? just curious, 'cuz the lower ring is huge and sloppy compared to the rest, has a bigger gap, and is a PITA to put in. (unless you know "the" technique.)
Seems strange that the tops rings in the box are right, and the oil ring isn't....
Old May 8, 2006 | 07:01 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Both compression rings are 5/64" thick. The oil ring groove is 3/16".
Old May 9, 2006 | 01:28 PM
Car: 1991 camaro RS
Thank you so much, now I can re-order the new ones.
Old May 9, 2006 | 07:55 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I like Sealed Power E251K. Pre-gapped, moly-faced top ring, available in overbored sizes.
Azrael91966669
25
Jun 20, 2017 04:04 AM
toronto formula
Nov 10, 2015 06:17 AM
Linson
Aug 21, 2015 02:12 PM
knight72
Aug 10, 2015 09:32 PM
jpearcy1
Wheels and Tires
Aug 9, 2015 10:20 AM
