angle milling heads
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
angle milling heads
Any of you guys have any good results angle milling heads?
We're gonna mill my trickflows to about a 55cc chamber, which should slightly change the valve angle to about 22* instead of 23*.
Will be 10:1 compression. Should be a pretty healthy motor I think. Desktop dyno says 503hp. Wonder what real life will see..
-- Joe
-- Joe
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
going to 55cc per chamber? What's the original size?
You have a blower don't you? sticking with it?
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Sold the blower. motor is going into a c4 vette, naturally aspirated, with a miniram.
-- Joe
ambainb
Apr 25, 2016 09:21 PM
evilstuie
Feb 28, 2016 03:33 PM
Magman
Sep 12, 2015 10:43 PM
gixxer92
Sep 1, 2015 04:32 PM
