86 Trans AM Won't Start
Old May 8, 2006 | 08:02 PM
Thrashdawg's Avatar
Car: 86 Trans Am
Engine: GM 350 LM1
Recently, I tried to start my 86 Trans Am, and as I turned the key, something popped and smoke came from the vents and under the dash. Now, when I turn the key, nothing happens. The guage cluster nor anything responds at all.
I tested the fusible links in the system and both are in working order. I then replaced the ignition switch and still, no luck. With the switch in the 'start' position, I tested the power wires leading to the starter and the alternator and both are receiving power.
The wiring diagram that I have is very simplistic. Does anyone know of relays that I should check and where they are located? Or, has anyone had a similar problem that can shed light on my situation? Thanks
Tommy Thrasher
Old May 8, 2006 | 08:21 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Well first off i would have the dash ripped apart fixing all the burnt wires/components...
Now if you are getting power to the starter solenoid on the small wire (red/brn/blk cant remember but its the only small one on the solenoid) you have a starter issue.
camaro11j
Sep 19, 2018 08:49 AM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
jharrison5
Aug 19, 2015 05:53 PM
mizz0313
Aug 12, 2015 06:45 AM
