This is driving me nuts!!!
Old May 9, 2006 | 07:54 AM
C6matt's Avatar
Car: 05 C6, 91 z28 Vert, 66 Mustang vert
Engine: Ls2, TPI 350, 289 4bbl
Transmission: T-56, T-5, C4
Axle/Gears: 3.42,3.08,3.73
I cant get the car to start, 91 Z28 M5 (350 with the 305 tpi I unit/heads,- BBK TB headers accel 30# injectors, mild injection cam ... I dont hear the fuel pump prime when I key on.... The fuel pump fuse is good... I ran a wire off the battery to the red fuel pump pig tail... it sparked but no sound out of the pump... is that the definitive sign for a bad pump? the car was running when it was parked in 01'
I also swapped relays with the cooling fan and the pump... no sound.... I just want to be sure its the pump before going through the hassle of R&Ring the tank.
Old May 9, 2006 | 11:29 AM
C6matt's Avatar
14 views, no one knows? I hope I'm not the first one to have this problem...
Old May 9, 2006 | 11:54 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Everyone, including you, will know a lot more after you go out and buy a fuel pressure gage and find out what the pressure is doing.
With the modifications you've listed, that should have been in your toolbox a long time ago.
Old May 9, 2006 | 12:28 PM
C6matt's Avatar
I have an electric fuel press gauge on the a pillar...I know I dont have pressure, I just want to make sure the pump is bad before I put all the time in replacing it...
Old May 9, 2006 | 12:38 PM
five7kid's Avatar
Okay, you didn't mention that. Are you sure the gage is working properly?
If you know you're getting electrical power to the pump, and you know you don't have a pressure restriction in the piping (fuel filter clogged, smashed line, etc.), then you've probably got your answer.
Certainly wouldn't be the first pump that died while sitting for an extended time.
Old May 9, 2006 | 12:42 PM
C6matt's Avatar
Thats what I was thinking... But I know what a pain these are to replace.... I just wanted to be sure... know what I mean...
Old May 9, 2006 | 10:40 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
What red wire exactly did you run power to exactly? The only red wire in the fuel pump control wiring is the wire that goes from the ALDL to the relay, as far as my diagram shows. If that holds true, that still doesn't rule out a ECM memory/fuel pump relay fuse. If that fuse blows out, then the relay doesn't get power. If that doesn't get power, then the "red" wire (still going on that assumption...) won't have any effect. The wire you want to give power to is the gray wire (12v out of the relay, to the pump).
Old May 10, 2006 | 05:12 AM
C6matt's Avatar
In a 91-92 there is a pigtail for fuel pump diagnostics/treoubleshooting... If you run a jumper wire to it the fuel pump will run, it bypasses the relay, opil press sensor, ignition, everything... so when I put a voltmeter on the fuel pump connector I get 13V at the pump... when I try to do it with the pump connected It sparks and the wire starts to heat up... si it looks as though the pump is toast...
Old May 10, 2006 | 06:19 PM
yupitsdadsbird's Avatar
Car: 91 RS
Engine: 5.0 tbi
it needs a pump most likely, and if your so perplexed bout the time to do it,.............................then cheat it and cut the hump and do it in the trunk like MOST other people.....if you have a lift that'll cut out like 2 hours in time....if your slow....with no lift like 4 hours
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Scamo-2.8
May 20, 2016 07:01 PM
Omega
Oct 1, 2015 02:20 PM
86IROC112
Aug 21, 2015 12:39 PM
mustangman65_79
Aug 8, 2015 12:07 PM
