How much power...
Old May 9, 2006 | 01:06 PM
ResurrectingZ's Avatar
Car: 1987 IROC 1991 RS
Engine: 5.7 TPI 5.0 TBI
Transmission: T-5 , 700R4
Axle/Gears: 2.73 twice
How much power...
Anybody have some ideas on how much power I should expect with this combination.....
96-00 Vortec block w/ flattops and valve reliefs
the infamous 113 heads with porting intake and polished exhausts
miniram on top with 58mm BBK tb
Hooker headers w/ dual 2 1/2" pipes w/ custom H-pipe stop short in front of axle
CC XR276HR-12 full kit
EGR delete, Smog Delete
I am hoping to reach my goal of 400HP at the flywheel, I think I can reach my goal. Any thoughts? Also is it worth keeping the vapor canister or should I ditch it also? Thanks.
Old May 9, 2006 | 10:56 PM
ttt
Old May 11, 2006 | 08:13 AM
Originally Posted by ResurrectingZ
ttt
bump
Old May 11, 2006 | 11:32 AM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
I would guess around 360-385hp.
Old May 12, 2006 | 08:47 AM
What about the vapor canister? Think I should ditch this, read in an earlier post these thing stop working after about 10 years. Any other opinions out there?
Old May 12, 2006 | 12:43 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Keep it. The Evap system is your friend.
Old May 12, 2006 | 12:53 PM
Okay it is still in then. I think all this with a set of 1.52 CC full roller rockers should help me accel like no other, maybe a MSD ignition later down the line. Get me a custom burned chip or I think it was fastchips or superchips, cant remember atm. My t-5 is going to die a horrible death...
Old May 15, 2006 | 12:53 PM
Okay, all this is about ready to be dropped into my 87, using an 89 superchip that i know wont work well but enough to start the beast, I will not have a cst switch or sensor so any other year is outta the question, still usin a MAF setup. The cold air intake is next for fabrication, anybody anticipate any problems with what my setup is going to be?
Old May 15, 2006 | 01:33 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
yes you CTS sensor contrbutes to the A/F ratio . It changes with different temps.
Old May 16, 2006 | 12:55 PM
Well I did not like it anyways, it was ugly and offensive.
alpine247
Brakes
16
Jan 11, 2008 11:45 AM
murky024
Dec 28, 2007 10:32 PM
orangetang
Jun 3, 2005 06:39 PM
