pic a block
Old May 9, 2006 | 10:11 PM
joey aucoin's Avatar
Car: '92 camaro rs 25th ann.
Engine: 1979 350 carbed w / built heads
Transmission: th 350 2500 TCI stall
Axle/Gears: 4.11 Richmond
pic a block
I have just completed the break down on a sb 355 and just before I started to order parts a friend of mine gave me a 400 sb . The 400 dose not have any thing in it and it needs to be bored ( just to clean it up ) . What would you do ,use the motor you have parts for or, start fresh on a 400 . I will have to use the stock 76 cc heads I had on the 350 for now . Any comments ?
Old May 9, 2006 | 10:13 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I'd probably build the one I already had parts for. You can accumulate parts to build the 400 over time.
Old May 9, 2006 | 10:17 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
If theres an up-time that you have to meet, then I agree with the above. Build the 400 up right.
Old May 9, 2006 | 10:39 PM
I dont have a time spand to keep up with . I can build either of them in the same amont of time and the caust will be pretty close to the same if i can use my old heads . I was just wondering if the 400 is that much better or not .
Old May 9, 2006 | 10:43 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Don't wreck a 400 with smogger-crap 76cc heads. The factory did and it was a total shame and then some.
I can attest to a 400 being better than a 350 (all else being equal). Either way, though, the heads are crap on either engine.
Old May 9, 2006 | 10:44 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
bigger motor is always better, maybe you could have the block mag'd and tanked first to see if it's a rebuildable core, then sell off the 350 pieces to buy stuff for your 406 then.
Old May 9, 2006 | 10:52 PM
bigdavesiroc's Avatar
Car: 87 iroc
Engine: 410 sbc
Transmission: tremec 3550
Axle/Gears: 30 spline 3.73
your're going to need a lot of "special" parts for the 400 and it would cost a little more to build. if time is an issue, i say go with the 355 and build the 400 as you go. my .02 cents. good luck
Old May 9, 2006 | 11:08 PM
Thank you all for your input . I think that i am going to use the 400 and maybe even my crap heads . I think that they are ok , they are accualy 1969 heads w / better valves and springs in them ( I am porting them my self ) . I will look into it alittle more before I start ordering parts . Thanks again.
Hotrodboba400
Dec 10, 2019 07:07 PM
Jorlain
Oct 8, 2015 01:57 AM
Nick McCardle
Sep 10, 2015 08:36 PM
64goatman
Sep 9, 2015 01:09 PM
rsrookie
Sep 5, 2015 07:08 PM
