continuing the EST saga
Old May 10, 2006 | 08:46 PM
redbird8628's Avatar
Car: 1986 Firebird
Engine: 3.4 outa 95' bird
Axle/Gears: 3.42 open rear
i did some more testing on my est problem, the car boggs and popps under heavy throttle and the tach spazzes out when the est bypass is plugged in, runs like a champ with it unplugged. i heard that the white est wire at the distributor gets 5 volts upon FULL ADVANCE. so i hooked up a multimeter on it...at idle it surges between about 1.8-2.6 volts and the tach surges with it... and revved her up....3 volts...ok..maybe there needs to be a load, i put the multi meter on my windshield and floored it across the parking lot at work...about 3.7 volts and the voltage surges when the tach surges? possibly a bad computer? i had to repair a partially melted plug at the computer, i smelled burning plastic one day, and the car stopped working, melted right at one of the ground wires, also the car makes a loose change clicking like noise, which isnt as bad on high test gas....but it did it on my last motor too, and since im only running with my base timing now, i dont think its detonation
db057
Apr 28, 2019 07:45 AM
Elephantismo
Feb 13, 2019 12:51 AM
L98GTA87
Oct 19, 2015 10:43 PM
3rdgenkindagal
Sep 13, 2015 02:02 PM
pacoelrapido
Sep 11, 2015 02:41 PM
