What injectors will work best with my 305
Old May 13, 2006 | 04:46 PM
Francis's Avatar
HI all.
I have a 305 TPI engine with a Holley stealth Ram.
I noticed that there was a Hypertech performance chip insalled by the last owner.
I also found out that it's running 22lb injectors.
What is the best way to set these up.
I have a set of 19lb injectors and a new Ac Delco Chip for it for the 19lb injectors.
THe 22lb ones are a bit of a mix and they are a bit old, so if I keep them I will have to look at getting new 22lb ones to work with the Hypertech chip or use my new 19lb ones with my Ac Delco chip.
Any thoughts?
Are these Hypertech chips any good, and do they really make that much difference over a stock style Ac Delco one?
Old May 13, 2006 | 05:01 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
What's the rest of the engine? Any other mods to it?
Off the shelf chips (Hypertech..) are generally disliked around here. You really need a custom PROM burned to get the most out of a modified engine, especially if its got an HSR. However, due to location, I'm not sure how easy that is.
Old May 13, 2006 | 05:08 PM
Francis's Avatar
HI, the rest of the engine as far as I know and can tell is stock. THe HSR is the only thing added on with a set of extractors and biger pipes. I hope to get a Comp Cams TPI stage 2 cam for it at a latter date, but for now it just off stock.
Thats why I thought about just making it as all stock, like using the 19lb injectors and the Ac Deco stock chip, but then when I found out it has 22lb injectors and that Hypertech chip I thouhgt I better hang on here, cuase I might be going back in power if I go stock injectors and chip.
jklein337
Sep 19, 2018 06:23 PM
pimp2303
Jul 27, 2017 02:03 PM
Jae992
Aug 27, 2015 09:07 AM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
